i built a SPI Master example based on this:SPI Master example
The example is a bit outdated and needed some rework and fix to work. I don't know if i am missing something, but SES complains and refuse to open the example because of some lack of coherence between overlay files and dts configurations. To make it work i had to modify the file:
..\nRF\ncs\zephyr\dts\bindings\spi\nordic,nrf-spim.yaml
In particular, this is how my yaml file is now:
# Copyright (c) 2019 Nordic Semiconductor ASA
description: Nordic nRF family SPIM (SPI master with EasyDMA)
compatible: "nordic,nrf-spim"
include: nordic,nrf-spi-common.yaml
properties:
miso-pull-up:
type: boolean
required: false
description: Enable pull-up on MISO line
miso-pull-down:
type: boolean
required: false
description: Enable pull-down on MISO line
ss-pin: <--ADDED FROM THIS LINE
type: int
required: false
description: Chip Select (CS) pin
spi-max-frequency:
type: int
required: false
description: SPI bus frequency in Hertz
With this modification and some minor changes to code and prj.conffile, adding a jumper wire between pin 11 and 12, the loopback example works with actual SDK. I can share the full project if needed.
Frax
