Could you please help me how to configure Timer-0/1/2 in timer mode with periodic interval.
With regards,
Praveen P
With regards,
Praveen P
Hi.
First, you might also want to take a look at Zephyr's timer API, even though these are software timers: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/reference/kernel/timing/timers.html
Other than that, I do not know about any other Zephyr API that access to timers. However, you can still use the nrfx drivers from the nRF5 SDK.
You can find the available API in <NCS>/modules/hal/nordic/nrfx/drivers/include/nrfx_timer.h.
Attached is a quick sample application that sets up an interrupt to happen every second.
Didrik
Hi Didrik,
Thank you for sharing me sample code.
regards,
Praveen
How can I create a timer, with the timeout is 5mn, after 5mn, it will enable GPS - THINGY:91?
In your code, I changed the TIMEOUT = 300000 // 5mn, but the interrupt always happened every second.
Hoang
Hi Hoang.
The counter only has 16 bits, so it is not able to count up to 300000 * ticks/ms.
However, I am not sure if I would use a timer for that in the first place. Instead, I would take a look delayed work items: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.2.0/zephyr/reference/kernel/threads/workqueue.html#delayed-work
Didrik
Dear Didrik Rokhaug,
the counter 16bits, xFFFF = 65 535 max value and with the
my_timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
--> T = 32us
16bits counter can count to 65535 x32us = 2,09712 s, is it correct?
I checked on the document:
| void nrfx_timer_compare | ( | nrfx_timer_t const *const | p_instance, |
| nrf_timer_cc_channel_t | cc_channel, | ||
| uint32_t | cc_value, | ||
| bool | enable_int | ||
cc_value is the ticks/ms, is it right ? how can we calculate this value from the TIMEOUT (as nrfx_timer_ms_to_ticks(&my_timer, TIMEOUT);)
Thanks so much
Hoang Nguyen
