I'm developing mesh nodes with serial interface, and have used the information in this thread to successfully modify the mesh firmware to support coded PHY
https://devzone.nordicsemi.com/f/nordic-q-a/29813/change-phy-in-mesh
I have been asked to add support for low power nodes and I'm finding that LPN-friend operation is very erratic with the coded PHY - I suspect that it's a timing issue, because sometimes friend requests and polls work, but mostly they do not.
I did have to make this change in core_tx_lpn.c
void core_tx_lpn_init(void)
m_lpn_bearer.broadcast.params.access_address = BEARER_ACCESS_ADDR_DEFAULT;
#if NRF_MESH_USE_CODED_PHY
m_lpn_bearer.broadcast.params.radio_config.radio_mode = RADIO_MODE_NRF_62K5BIT;
#else
m_lpn_bearer.broadcast.params.radio_config.radio_mode = RADIO_MODE_BLE_1MBIT;
and similarly in core_tx_friend_init() in the friend node.
I suspect there are some subtle timing changes that might be needed in the LPN and possibly in the friend - I'd really appreciate any help or pointers you could offer. Thanks.
(You might be wondering why have a LPN with coded PHY - the answer is just so we can run all mesh nodes with coded PHY for range)
