Using customer registers to pass initialization data
I have this scenario : I want each of my board to have a set of unique data, that I want to write along with the program, at the board initialization (this data will be uses the first time the board boots).
I have understood that I could use customer registers (in UICR) for that.
If I program my board (with "nrfjprog --program ..."), then try to write to customer registers, nrfjprog tells me they are protected, which I get.
So I tried the contrary :
- erasing all
- writing to customer register
- program the board
- read from customer register from app
Unfortunately, I succeed writing to customer register, but they are overwritten after programming.
NRF52811
SD s112 7.0.1
SDK 16.0.0
$ nrfjprog --eraseall
    Erasing user available code and UICR flash areas.
    Applying system reset.
$ nrfjprog --memwr 0x80 --val 0x195B6635
    Parsing parameters.
    Writing.
$ nrfjprog --memrd 0x080 --n 8
    0x00000080: 195B6635 FFFFFFFF |5f[.....|
$ nrfjprog --program .my_app_bl_sd_app.hex --verify --chiperase (containing app+settings+bootloader+softdevice)
    Parsing hex file.
    Checking that the area to write is not protected.
    Programming device.
    Verifying programming.
    Verified OK.
    0x00000080: 000007FB 00000805 |........|
What am I missing ?
Thanks !
    0x80 is a main flash memory. Here's the right way to write UICR:
    nrfjprog --memwr 0x10001080 --val 0x195B6635
    But --chiperase will clear UICR as well...
  • Thanks ! I missed that address information in the documentation
    Indeed it works with :
    $ nrfjprog --memwr 0x10001080 --val 0x195B6635
        Parsing parameters.
        Writing.
    $ nrfjprog --program .my_app_bl_sd_app.hex --verify (without --chiperase, not necessary in this case)
        Parsing hex file.
        Reading flash area to program to guarantee it is erased.
        Programming device.
        Verified OK.
    $ nrfjprog --memrd 0x10001080 --n 8
        0x10001080: 195B6635 FFFFFFFF |5f[.....|
    Perfect !
