Hi Nordic,
There is a question about the default setting for Advertising PHY type. if there is no config value setting like case (PHY_1M ) . (all memory already set to 0 ).
case PHY_CODED :
BLE_LOG_INFO("--> BLE_Adv Range Mode set to %s", "PHY_CODED");
cfg->config.ble_adv_primary_phy = BLE_GAP_PHY_CODED;
cfg->config.ble_adv_secondary_phy = BLE_GAP_PHY_CODED;
cfg->config.ble_adv_extended_enabled = true;
case PHY_2M :
BLE_LOG_INFO("--> BLE_Adv Range Mode set to %s", "PHY_2M");
cfg->config.ble_adv_primary_phy = BLE_GAP_PHY_2MBPS;
cfg->config.ble_adv_secondary_phy = BLE_GAP_PHY_2MBPS;
case PHY_1M :
BLE_LOG_INFO("--> BLE_Adv Range Mode set to %s", "PHY_1M");
cfg->config.ble_adv_extended_enabled = false;
what is the default PHY setting after Initial ? Thanks.
