sometime host cannot deactivate the LTE when the network registration status is 2
Similar to https://devzone.nordicsemi.com/f/nordic-q-a/57105/nrf9160-modem-stuck-in-searching/231773
We found sometime the LTE cannot be deactivated during the modem is trying to attach or searching network;
It can be reproduced by below steps:
Condition: there is no catM1 network and no NB network(You can assume it is in shielded room)
1), AT+CEREG=5
2), AT+CFUN=21
Wait until the the CEREG notified "+CEREG: 2,....."
3), AT+CFUN=20
Sometime the network registration status cannot chage to 0 even the result of AT+CFUN?  is "+CFUN: 4"
It can be found both catM1(AT%XSYSTEMMODE=1,0,1,0) and NB(AT%XSYSTEMMODE=0,1,1,0) mode.
modem fw version: mfw_nrf9160_1.1.1
  • Hi.
    When I tested this, I did not see this behavior.
    While I do have both NB-IoT and LTE-M network at my home office, I do not have a shielded box. However, my iBasis SIM card does not support my local NB-IoT network, so it will not be able to attach to the network.
    I have attached a log from my test, as you can see, +CEREG reports that the modem is offline. The test was done using the at_client from NCS v1.2.0.
    Could you provide a modem trace that shows this behavior?
    Didrik
    at%xsystemmode=0,1,0,0
    OK
    at+cereg=5
    OK
    at+cfun=21
    OK
    at+cfun?
    +CFUN: 1
    OK
    +CEREG: 2,"9DD1","01082D66",9,0,0,"11100000","11100000"
    at+cfun=20
    +CEREG: 0,"9DD1","01082D66",9,0,0,"11100000","11100000"
    OK
    at+cfun?
    +CFUN: 4
    OK
    at+cereg?
    +CEREG: 5,0,"9DD1","01082D66",9,0,0,"11100000","11100000"
    OK
    at+cgmr
    mfw_nrf9160_1.1.1
    OK
    Please check below our test cmd log and trace based on at_client sample from NCS v1.2.0
    2020-04-09T03:34:21.716Z INFO Modem port is opened
    2020-04-09T03:34:25.041Z DEBUG modem >> AT+CGMR\x0D\x0A
    2020-04-09T03:34:25.064Z DEBUG modem << mfw_nrf9160_1.1.1\x0D\x0A
    2020-04-09T03:34:25.067Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:34:31.719Z DEBUG modem >> AT%HWVERSION\x0D\x0A
    2020-04-09T03:34:31.734Z DEBUG modem << %HWVERSION: E218\x0D\x0A
    2020-04-09T03:34:31.737Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:34:39.576Z DEBUG modem >> AT%XSYSTEMMODE=1,0,1,0\x0D\x0A
    2020-04-09T03:34:39.594Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:34:45.594Z DEBUG modem >> AT+CGDCONT=0,"IP","test"\x0D\x0A
    2020-04-09T03:34:45.612Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:34:52.345Z DEBUG modem >> AT%XBANDLOCK=2,"1000000000010000001"\x0D\x0A
    2020-04-09T03:34:52.361Z DEBUG modem << OK\x0D
    2020-04-09T03:34:59.120Z DEBUG modem >> AT%XSYSTEMMODE?\x0D\x0A
    2020-04-09T03:34:59.136Z DEBUG modem << %XSYSTEMMODE: 1,0,1,0\x0D\x0A
    2020-04-09T03:34:59.138Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:35:07.857Z DEBUG modem >> AT+CEREG=5\x0D\x0A
    2020-04-09T03:35:07.871Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:35:14.466Z DEBUG modem >> AT+CFUN=21\x0D\x0A
    2020-04-09T03:35:14.510Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:35:30.876Z DEBUG modem << +CEREG: 2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"\x0D\x0A
    2020-04-09T03:35:34.619Z DEBUG modem >> AT+CFUN=20\x0D\x0A
    2020-04-09T03:35:34.639Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:35:41.451Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2020-04-09T03:35:41.469Z DEBUG modem << +CEREG: 5,2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"\x0D\x0A
    2020-04-09T03:35:41.477Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:35:50.938Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-04-09T03:35:50.957Z DEBUG modem << +CFUN: 4\x0D\x0A
    2020-04-09T03:35:50.974Z DEBUG modem << OK\x0D\x0A
    2020-04-09T03:35:56.352Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2020-04-09T03:35:56.370Z DEBUG modem << +CEREG: 5,2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"\x0D\x0A
    2020-04-09T03:35:56.380Z DEBUG modem << OK\x0D\x0A
    trace-2020-04-09T03-33-52.630Z.bin
  • Hi, and sorry for the late reply.
    Sadly, your modem trace is empty, so I can not read anything from it. A proper modem trace easily reaches a size of several hundred kilobytes if not more, and with the LTE stack enabled it should grow with several kilobytes per second.
    Could you try to capture a new trace?
    Make sure that CONFIG_BSD_LIBRARY_TRACE_ENABLED=y is set, and that you have issue AT%XSYSTEMMODE=1,2
  • I have had a talk with the modem team, and they believe that the behavior you are seeing is because of a bug in the modem that leads to the CEREG stat not being updated.
    AT+CFUN? correctly returns that the modem is offline, while AT+CEREG? has not been updated to show that the modem is offline. They are looking into the root of the bug.
  • Hi
    This issue still exist on mfw_nrf9160_1.2.0, is there any update or workaround?
