SES - aborting nRF project loading due to Kconfig warnings
I've successfully passed nRF Connect SDK installation by using GSA application (macOS 10.15.3, python 3.7.7, west 0.6.3).
Now I'm in the SES 4.52c and have a problem in loading a project with
CMakeLists.txt = <ncs>/nrf/applications/asset_tracker/CMakeLists.txt
Board Directory = <ncs>/zephyr/boards/arm/nrf5340_dk_nrf5340
Board Name  = nrf5340_dk_nrf5340_cpuapp
Build Directory  = <ncs>/nrf/applications/nrf_desktop/build_nrf5340_cpuapp
The loading is aborted and the Output Transcript panel shows:
Loading solution asset_tracker.emProject
Executing load commands
/usr/local/bin/cmake -GNinja -DBOARD=nrf5340_dk_nrf5340_cpuapp -DBOARD_DIR=/Users/gabrielefilosofi/fot-dev/ncs/zephyr/boards/arm/nrf5340_dk_nrf5340 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/Users/gabrielefilosofi/gnuarmemb/gcc-arm-none-eabi-8-2019-q3-update -B/Users/gabrielefilosofi/fot-dev/ncs/nrf/applications/asset_tracker/build_nrf5340_dk_nrf5340_cpuapp -H/Users/gabrielefilosofi/fot-dev/ncs/nrf/applications/asset_tracker -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DCMAKE_MAKE_PROGRAM=/usr/local/bin/ninja -DDTC=/usr/local/bin/dtc -D WEST=/usr/local/bin/west -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/Users/gabrielefilosofi/arm_segger_embedded_studio_v452_macos_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Zephyr version: 2.1.99
-- Selected BOARD nrf5340_dk_nrf5340_cpuapp
-- Found west: /usr/local/bin/west (found suitable version "0.6.3", minimum required is "0.6.0")
-- Loading /Users/gabrielefilosofi/fot-dev/ncs/zephyr/boards/arm/nrf5340_dk_nrf5340/nrf5340_dk_nrf5340_cpuapp.dts as base
nrf5340_dk_nrf5340_cpuapp.dts.pre.tmp:92.42-104.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@50000000/kmu@39000)
nrf5340_dk_nrf5340_cpuapp.dts.pre.tmp:365.19-371.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
Devicetree configuration written to /Users/gabrielefilosofi/fot-dev/ncs/nrf/applications/asset_tracker/build_nrf5340_dk_nrf5340_cpuapp/zephyr/include/generated/devicetree.conf
Parsing /Users/gabrielefilosofi/fot-dev/ncs/nrf/applications/asset_tracker/Kconfig
/Users/gabrielefilosofi/fot-dev/ncs/nrf/lib/fprotect/Kconfig:20: WARNING: dt_int_val is deprecated.
/Users/gabrielefilosofi/fot-dev/ncs/bootloader/mcuboot/zephyr/Kconfig:37: WARNING: dt_int_val is deprecated.
Loaded configuration '/Users/gabrielefilosofi/fot-dev/ncs/zephyr/boards/arm/nrf5340_dk_nrf5340/nrf5340_dk_nrf5340_cpuapp_defconfig'
Merged configuration '/Users/gabrielefilosofi/fot-dev/ncs/nrf/applications/asset_tracker/prj.conf'
warning: BSD_LIBRARY (defined at /Users/gabrielefilosofi/fot-dev/ncs/nrf/lib/bsdlib/Kconfig:8) has direct dependencies TRUSTED_EXECUTION_NONSECURE with value n, but is currently being y-selected by the following symbols:
- MODEM_INFO (defined at /Users/gabrielefilosofi/fot-dev/ncs/nrf/lib/modem_info/Kconfig:7), with value y, direct dependencies y (value: y)
error: Aborting due to Kconfig warnings
