Hello NORDIC
We found that TX frequency error is quite large. Is it able to compensate TX frequency by software ?
Hello NORDIC
Yes, BLE parameter can be measured by IQXel device .We hope a little frequency error can be compensated by software .
I agree the softdevice would likely be an issue. Plus from what you can learn from the reference manual it sounds like the registers would be loaded with factory calibration data by the softdevice. It would be better to address the tuning of the circuit.
Yes, we are running a softdevice when we test BLE . My team menber told me that BT Tx frequency can offset by registers and we can creat a array to offset the error . What do you think about it ?
I've said what I think about it twice now, you can't do it. Trim registers do exist which possibly allow TX frequency trimming for proprietary uses of the radio, however they are both relatively undocumented and, more importantly, they are part of the RADIO module. When using a softdevice the RADIO module is restricted, the softdevice owns it, you are not allowed to access any of the registers.
As John DeWitt points out above, the manual strongly suggests that the trim registers are likely loaded with the factory calibrated values from the FICR when the softdevice is started, and once it's started, you have no access to them.
Nordic provides no radio API point I can find which allows you to change those, or adjust the TX frequency in any way so I can see no provided way for you to do this.
ok,thank you so much !
