We are experiencing 2 different but related app_timer failure conditions.
- app_timer_create() returns NRF_ERROR_INVALID_STATE
- app_timer_start() does not return an error but the timer does not start
According to the documentation, both of these failure conditions are caused by app_timer_id_t being in the "running" state. We created a app_timer_pool.c module which manages a pool of timers. This has been working flawlessly for 4 years. If try to restart a running timer. The current timer is stopped. A new timer is retrieved from the pool, configured and started.
I have instrumented the code to monitor for various resource issues. Everything looks good.
0> Stack: max used=1872 remaining=2224 0> schedule: state=23, index=6, exec_state=1, residual=0 0> timers: max=3, pool: cur=7,max=12 eventq: max=9
- 3K stack configured, max used 1872 bytes
- APP_TIMER_CONFIG_OP_QUEUE_SIZE 10, monitor reports max used = 3
APP_SCHED_INIT(EVENT_SIZE, 32), monitor reports max used = 9
APP_TIMER_POOL_SIZE 15, monitor reports max used = 12, currently using 7
The timer pool app_timer_create() 15 timers at startup. Starting a timer allocates a free timer from the pool, configures and starts it. Stopping a timer calls app_timer_stop() and then returns the timer to the pool.
The log demonstrates app_timer_start(), not actually starting the timer. You can see the timer was Taken from the pool but since it is not running the application stops.
0> ReleaseTimer ID 11 0> 0:08:14.108 RAMPING STOP RAMPING -> IDLE 0> 0:08:14.108 STIM EVENT: RAMP STOP DONE 0> TakeTimer ID 12 0> ReleaseTimer ID 12 0> 0:08:14.220 STIM EVENT: DISCHARGE DONE 0> 0:08:14.220 STIM STATE: SCHEDULED IDLE 0> 0:08:14.221 SCHEDULE EVENT: STIM RUNNING -> STIM START 0> 0:08:14.221 Schedule started: residual=x00002800, stop=x0007E0E3, now=x0007B8E3 0> 0:08:14.222 schedule_stim_start_state_event_handler start timer 0> TakeTimer ID 13 0> 0:08:14.222 SCHEDULE STATE: STIM RUN 0> 0:08:14.300 ADV: Sys=FFFFFFFF Dev=1 VBat=3897 Amp={25 63 63 63} Sched=17/12 Err=00 Col=02 Prg=2 Ins=1 Post=2 Stim=0 LowP=0 LowB=0 Sess=1 Buzz=1 0> 0:08:15.222 schedule_timer_handler RUNNING 0> 0:08:15.662 STIM EVENT: STIM SETUP STARTED 0> Program dequeued 0> Schedule IDLE started 0> 0:08:24.222 SCHEDULE EVENT: TIMEOUT -> STIM RUN 0> Schedule: Starvation_period[0]=50 0> Schedule: Starvation_period[1]=40 0> Schedule: Starvation_period[2]=30 0> Schedule: Starvation_period[3]=20 0> Schedule: Starvation_period[4]=10 0> Schedule: Starvation_period[5]=0 0> Schedule: Starvation_period[6]=150 0> Schedule: Starvation_period[7]=140 0> Schedule: Starvation_period[8]=130 0> Schedule: Starvation_period[9]=120 0> Schedule: Starvation_period[10]=110 0> Schedule: Starvation_period[11]=100 0> Schedule: max_starve_time=0 sec 0> 0:08:24.224 STIM EVENT: STOP (3) 0> Selected Program=3 0> Program queued, ID=3 0> Program queued, ID=3 0> 0:08:24.225 STIM STATE: CONNECTED IDLE 0> Program queued, ID=3 0> Program change request during program startup, queued=3 0> Next Program=3 0> Current program set to committed program 3 0> 0:08:24.234 STIM EVENT: START 0> MRU program ID=3 0> Program dequeued 0> 0:08:24.241 Auto timer stopped 0> 0:08:24.242 STIM STATE: STIM REQUESTED 0> 0:08:24.263 ADV: Sys=FFFFFFFF Dev=1 VBat=3868 Amp={25 63 63 63} Sched=17/12 Err=00 Col=02 Prg=3 Ins=1 Post=2 Stim=2 LowP=0 LowB=0 Sess=1 Buzz=1 0> 0:08:25.386 STIM EVENT: STIM SETUP STARTED 0> Program dequeued 0> Stim setup started, current=3, queued=255 0> 0:08:25.386 STIM STATE: RAMP TO TARGET 0> 0:08:25.387 RAMPING IDLE -> STARTING 0> TakeTimer ID 14 0> 0:08:25.457 ADV: Sys=FFFFFFFF Dev=1 VBat=3868 Amp={25 63 63 63} Sched=17/12 Err=00 Col=02 Prg=3 Ins=1 Post=2 Stim=3 LowP=0 LowB=0 Sess=1 Buzz=1 0> Stack: max used=1872 remaining=2224 0> schedule: state=23, index=6, exec_state=1, residual=0 0> timers: max=3, pool: cur=7,max=12 eventq: max=9 0> Stack: max used=1872 remaining=2224 # Logging stopped @ 09 Apr 2020 15:24:06 Notes: 1. Changed timer to use app_scheduler for callbacks 2. Enabled app_scheduler monitor. Max queue size 9. Allocated size 32. 3. No INVALID_STATE errors in this log. 4. Fails starting the stimulation ramp timer.
For the app_timer_create() returning NRF_ERROR_INVALID_STATE, I was able to add code to continue and get the next timer in the pool. Invariably the log would show the "running" timer being used sometime in the future. Unfortunately there is no error indication in the app_timer_start() case.
Log of allocate and free only.
0> TakeTimer ID 18
0> ReleaseTimer ID 18
0> TakeTimer ID 19
0> ReleaseTimer ID 19
0> TakeTimer ID 0
0> ReleaseTimer ID 0
0> TakeTimer ID 2
0> ReleaseTimer ID 2
0> TakeTimer ID 4
0> TakeTimer ID 5
0> TakeTimer ID 7
0> TakeTimer ID 8
0> TakeTimer ID 9
0> TakeTimer ID 11
0> ReleaseTimer ID 8
0> ReleaseTimer ID 7
0> TakeTimer ID 12
0> TakeTimer ID 13
0> ReleaseTimer ID 13
0> ReleaseTimer ID 9
0> TakeTimer ID 14
0> ReleaseTimer ID 14
0> ReleaseTimer ID 4
0> TakeTimer ID 15
0> ReleaseTimer ID 15
0> TakeTimer ID 16
0> ReleaseTimer ID 16
0> TakeTimer ID 17
0> ReleaseTimer ID 17
0> TakeTimer ID 18
0> TakeTimer ID 19
0> TakeTimer ID 0
0> TakeTimer ID 2
0> TakeTimer ID 4
0> TakeTimer ID 7
0> TakeTimer ID 8
0> TakeTimer ID 9
0> TakeTimer ID 11
0> TakeTimer ID 12
0> TakeTimer ID 13
0> TakeTimer ID 14
0> TakeTimer ID 15
0> TakeTimer ID 16
0> TakeTimer ID 17
0> TakeTimer ID 18
0> TakeTimer ID 19
0> TakeTimer ID 0
0> TakeTimer ID 2
0> TakeTimer ID 4
0> TakeTimer ID 7
0> TakeTimer ID 8
0> TakeTimer ID 9
0> TakeTimer ID 11
