Nfr Toolbox
Bonjour, je ne peux pas télécharger un firmware via l'application nfr toolbox avec mon Huawei p8 pour mon home trainer connecté, via bluetooth. Je reste bloqué à 2% et un message "uploding failed gatt error" apparait.
Merci de votre aide car je suis novice.
Rapport d'erreur sur nfr connect.
Merci
nRF Connect, 2020-04-10 MINOURA SMART 5318 (D4:34:17:D9:9A:BE) V 16:04:30.225 Connecting to D4:34:17:D9:9A:BE... D 16:04:30.225 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 16:04:30.809 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 16:04:30.809 Connected to D4:34:17:D9:9A:BE D 16:04:30.869 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED V 16:04:30.889 Discovering services... D 16:04:30.889 gatt.discoverServices() I 16:04:31.205 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) D 16:04:31.958 [Callback] Services discovered with status: 0 I 16:04:31.958 Services discovered V 16:04:32.022 Generic Access (0x1800) - Device Name [R] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) Battery Service (0x180F) - Battery Level [N R] (0x2A19) Client Characteristic Configuration (0x2902) Device Information (0x180A) - Manufacturer Name String [R] (0x2A29) - Serial Number String [R] (0x2A25) - Hardware Revision String [R] (0x2A27) - Firmware Revision String [R] (0x2A26) Unknown Service (a026ee01-0a7d-4ab3-97fa-f1500f9feb8b) - Unknown Characteristic [N WNR] (a026e002-0a7d-4ab3-97fa-f1500f9feb8b) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N] (a026e004-0a7d-4ab3-97fa-f1500f9feb8b) Client Characteristic Configuration (0x2902) Unknown Service (a026ee03-0a7d-4ab3-97fa-f1500f9feb8b) - Unknown Characteristic [N WNR] (a026e00a-0a7d-4ab3-97fa-f1500f9feb8b) Client Characteristic Configuration (0x2902) Cycling Power (0x1818) - Cycling Power Measurement [N] (0x2A63) Client Characteristic Configuration (0x2902) - Cycling Power Feature [R] (0x2A65) - Sensor Location [R] (0x2A5D) - Unknown Characteristic [I W] (a026e005-0a7d-4ab3-97fa-f1500f9feb8b) Client Characteristic Configuration (0x2902) - Cycling Power Control Point [I W] (0x2A66) Client Characteristic Configuration (0x2902) Device Firmware Update Service (00001530-1212-efde-1523-785feabcd123) - DFU Packet [WNR] (00001532-1212-efde-1523-785feabcd123) - DFU Control Point [N W] (00001531-1212-efde-1523-785feabcd123) Client Characteristic Configuration (0x2902) - DFU Version [R] (00001534-1212-efde-1523-785feabcd123) D 16:04:32.022 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) D 16:04:32.027 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true) D 16:04:32.031 gatt.setCharacteristicNotification(a026e002-0a7d-4ab3-97fa-f1500f9feb8b, true) D 16:04:32.033 gatt.setCharacteristicNotification(a026e004-0a7d-4ab3-97fa-f1500f9feb8b, true) D 16:04:32.037 gatt.setCharacteristicNotification(a026e00a-0a7d-4ab3-97fa-f1500f9feb8b, true) D 16:04:32.039 gatt.setCharacteristicNotification(00002a63-0000-1000-8000-00805f9b34fb, true) D 16:04:32.043 gatt.setCharacteristicNotification(a026e005-0a7d-4ab3-97fa-f1500f9feb8b, true) D 16:04:32.045 gatt.setCharacteristicNotification(00002a66-0000-1000-8000-00805f9b34fb, true) I 16:04:32.060 Connection parameters updated (interval: 50.0ms, latency: 0, timeout: 5000ms) I 16:04:36.559 Connection parameters updated (interval: 50.0ms, latency: 0, timeout: 6000ms) V 16:04:40.778 Starting pairing... D 16:04:40.778 device.createBond() D 16:04:40.843 [Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11) I 16:04:41.167 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) D 16:04:46.232 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0) E 16:04:46.233 Error 8 (0x8): GATT CONN TIMEOUT I 16:04:46.233 Disconnected D 16:04:46.365 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:04:46.380 [Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_NONE (10) I 16:04:46.380 Bonding failed V 16:04:52.054 Starting pairing... D 16:04:52.054 device.createBond() D 16:04:52.073 [Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11) D 16:04:52.461 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED D 16:04:52.461 gatt.close() D 16:04:52.480 wait(200) V 16:04:52.681 Connecting to D4:34:17:D9:9A:BE... D 16:04:52.681 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 16:04:52.700 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 16:04:52.700 Connected to D4:34:17:D9:9A:BE I 16:04:52.859 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) D 16:04:57.926 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0) E 16:04:57.926 Error 8 (0x8): GATT CONN TIMEOUT I 16:04:57.926 Disconnected D 16:04:58.060 [Br
