Hi all,
Based on the EddystoneBeacon example (ble_app_eddystone), I try and change the advertising slot contents runtime from main.c on a button press. I read similar questions here in the Devzone, and as expected this pointed me to the usage of es_slot_on_write, but things don't work out as I want it to be. When I write the new data to slot 0, the application resets after reporting a Fatal error. When I write to slot 1, 2 or 3, nothing changes and the application keeps sending the earlier set Default data. Here is what I try to do in the Button event handle:
static uint8_t TestData[20] = {
APP_ES_UID_FRAME_TYPE, DEFAULT_FRAME_TX_POWER,
0x33, 0x33, 0x44, 0x44, 0x55, 0x55, 0x44, 0x44, 0x33, 0x33, //10-byte UID namespace
0x07, 0x07, 0x07, 0x07, 0x07, 0x07, //6-byte UID ID
0x00, 0x00
/**@brief Function for handling button events from app_button IRQ
* @param[in] pin_no Pin of the button for which an event has occured
* @param[in] button_action Press or Release
static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
if (button_action == APP_BUTTON_PUSH && pin_no == BUTTON_1) {
// nrf_ble_es_on_start_connectable_advertising();
es_slot_on_write(0, 20, TestData);
if (button_action == APP_BUTTON_PUSH && pin_no == BUTTON_2) {
es_slot_on_write(1, 20, TestData);
With some debug prints I see it ending up in configure_slot as should be, but it does not work so I must do something wrong:
- Do I need to call extra functions to get this working as should be?
- Can it be the TestData frame contents, are the test-values for the UID-Frame for some reason invalid?
- Some other cause?
I'm using nrf52840-DK and nRF5 SDK v.16.0
Thanks in advance for your reply
