Hello.
This function from Zigbee SDK 4.0.0 changes configuration of already configured input pin by calling nrf_gpio_cfg_default(ERASE_PIN);
/**@brief Function to set the Erase persistent storage depending on the erase pin
zb_void_t zigbee_erase_persistent_storage(zb_bool_t erase)
#if defined (BOARD_PCA10056) || defined (BOARD_PCA10059) || defined (BOARD_PCA10100)
if (!erase)
nrf_gpio_cfg_input(ERASE_PIN, NRF_GPIO_PIN_PULLUP);
int i;
volatile uint32_t pin_state;
/* Read a few times to make sure the value in the register has been updated. */
for (i = 0; i < READ_RETRIES; i++)
pin_state = nrf_gpio_pin_read(ERASE_PIN);
if (pin_state == 0)
erase = ZB_TRUE;
NRF_LOG_INFO("Forcing flash erasure due to pin state");
zb_set_nvram_erase_at_start(erase);
The leds_buttons_init() function in main() configures the GPIO pin for user button, but a subsequent call to the zigbee_erase_persistent_storage() function returns the default configuration, so the button does not work as expected.
/**@brief Function for application main entry.
zb_ret_t zb_err_code;
zb_ieee_addr_t ieee_addr;
/* Initialize timer, logging system and GPIOs. */
timer_init();
log_init();
leds_buttons_init();
/// Unrelated code removed
zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
This behavior is present at least in the zigbee/light_control/light_bulb example for the pca10059 board, but I have a suspicion that this works the same way in other examples.
