I have created a system with nRF52840 (peripheral) that collects data from an accelerometer and gyroscope sensors and sends those data through ble_uart to a smartphone device (central) for visual inspection (graph).
The system works fine but now I want to move a step further and send sensor data from multiple peripherals simultaneously to the same smartphone device so that I can display data from all devices in the same graph
The possible configurations I can think of, are the following.
- 1st possible Configuration
- Collect the data from multiple peripheral devices simultaneously and
- display those data on smartphone app
- 2nd Possible Configuration
- send them to an nRF52840 central device that assemblies all that data into packets and then
- send those packets to a smartphone device and display them
The problem is that, I don't know if and how multiple peripherals can be connected all together at the same time
to a central (either configuration 1 or 2) in order to receive data from all devices simultaneously.
Do you know if there is some example or tutorial that does that, so I can use it as basis ?
Thank you for your time
Best regards
