the uart examle doesn't work for all pins, for most pins i tried actually.
Hi.
I have nrf52840-dk board.
i tried the UART example from the peripherals directory. it works with the default, if i open a console on /dev/ttyACM0 and on /dev/ttyUSB0 i can see the "start" message and pressing a key echos it back.
/dev/ttyUSB0 is a usb TTL i have that is connected to my laptop and to (at first) p0.06, p08.
problem started when i tried to change the pins to p0.9 and p0.10. i didn't change anything else, just the pins numbers.
BTW i tried the armgcc (make) and ses.
i see nothing not on ACM0 nor on USB0.
without debugging only running JLinkExe and halt i can see IPSR is 012, which is debug reserved flag, i guess it means the processor reached the error handler.
trying to debug indeed i reach the error handler from within the event handler of the uart, removing the calls to `APP_ERROR_HANDLER` allows the program to run but still not output on the USB0 port.
i tried ports i saw in other example i think it was p0.27' it wokred, but port 17,19,20,21 did not.
I don't get it, either you CAN use all ports that are not used to something else (i tried 00 and 01 but i understand they connect to the crystal...) or you can't how can it be that ii'm currently able to use only 4 pins ????
is there  a list of pins i can use ? and is that list relevant only for ntf52840-dk or to any device using nrf52840 chips ?
Do these pins also work for uarte ?
  • OK, I think we both were on different page in understanding the problem.
    1. Just having UART communication between two devices you can use any pins from the nRF52840 chip.
    2. On DK, for simplicity and to make your evaluation and prototyping easy, we have assigned few GPIO pins to certain features. Like few GPIOs are connected to buttons few of them to LEDS and few as you see on the back side of the DK. This settings are only for the DK and on your final product you can choose different pins.
    3. On nRF52840 DK, pin 09 and 10 are connected to NFC and as I mentioned you need to define the macro in your project and you can still use those pins for any other peripehral. In your case, after defining CONFIG_NFCT_PINS_AS_GPIOS , you can use pin 09 and 10 for uarte0.
    4. If you want to see your uarte0 data on PC, then the pins needs to be mapped into a COM port on your PC. And this can only happen with the CDC driver which is inside the Segger chip on the DK. The Segger chip listens to the pre allocated TX/RX/RTS/CTS pins on the DK and converts them into a COM port CDC data that your PC can listen in any terminal.
    5. The UART data is NOT automatically converted into /dev/ttyACM0 or /dev/ttyUSB0 mapping on your linux machine without the segger chip showing up as a COM device.
    6. on your final product, most likely you will not have the segger, debugger chip. That means all uarte0 data on your final product, you will not be able to see it directly on the PC terminal unless you connect to some COM adapter.
    I think the confusion that arises for you is that you think you can use any pins for uarte. Which is correct on your final product. To be able to automatically have COM port mapped on your PC, we assigned few UART pins that the SEGGER chip listens to and converts them to CDC UART data that your PC maps onto a COM port.
    I hope that this is a bit clearer.
  • Thanks for that :-) but that's not what i meant.
    I mean indedd 06 and 08 works just fine, however, when i'm using other pins i'm not using /dev/ttyACM0, i have a usb TTL (serial to usb) that is connected to my pc using usb and to the DK board on the other side. like i wrote in the original post.
    let's drop 9,10 , i know some ports are used for leds\xtel\buttons etc....
    as far as i know all of them were supposed to be printed on the back of the DK board, apparently they are not...
    So i'll rephrase.
    i want to communicate between my DK board and a usb to serial board connected to my PC.
    I want to use the uart example and maybe replace the printf with a function that outputs everything to the uarts. which pins beside 8 and 6 i can use without  changing configuration in sdk_config.
    hops it clarifies my question (it is device to device comm)
  • You can use any pins your application does not use and you need the below converter to convert uart to RS232 data as below
    If you do not have this converter then use the pins assigned on DK 08 and 06 which will do the conversion for you through the USB COM port emulation.
  • Yes you can use any pins except those already connected to something on the DK.  If you use it on a breakout board for example that has all the pins available and not connected anything then yes any pins can be used. Except NFC, you need to disable NFC function in order to use it as gpio.  So again I repeat, any gpio pin can be used as UART, I2C or SPI. Pleas read the datasheet.  The pin 9 & 10 of NFC are described  in there.
  • ok, taking a look on user manual i see the point. the pins i used are using for external flash memory. it's not marked on the board itself :-\ so from pin 0.27 i have several options i see. ok.
    You sat on nrf52850-mini basically every pin can be used for serial ?
