NRF52 SDK16 Only Data in first characteristic seen by nrf connect in custom service
i have built my own custom service.
I have 13 characteristics ....
But in NRF Connect on an iphone, i can see 13 characteristics , but only in the first there data.
Any hints, Idea's
regards Andreas
StrDesc[i] , StrData[i  are String Arrays
-> Handles   ble_gatts_char_handles_t      custom_value_handlex[13];
uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
    if (p_cus == NULL || p_cus_init == NULL)
        return NRF_ERROR_NULL;
    int i ;
    uint32_t   err_code;
    ble_uuid_t ble_uuid;
    // Initialize service structure
    p_cus->evt_handler               = p_cus_init->evt_handler;
    p_cus->conn_handle               = BLE_CONN_HANDLE_INVALID;
    // Add Custom Service UUID
    ble_uuid128_t base_uuid = {CUSTOM_SERVICE_UUID_BASE};
    err_code =  sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
    ble_uuid.type = p_cus->uuid_type;
    ble_uuid.uuid = CUSTOM_SERVICE_UUID;
    // Add the Custom Service
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
    if (err_code != NRF_SUCCESS)
        return err_code;
     for ( i = 0 ; i < 13 ; i++ )
        custom_value_char_add2(p_cus, p_cus_init , StrDesc[i] , StrData[i] , i );
   return NRF_SUCCESS ;
static uint32_t custom_value_char_add2(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init , char *Str , char *Str2, uint8_t p)
    uint32_t            err_code;
    ble_gatts_char_md_t char_md;
    ble_gatts_attr_md_t cccd_md;
    ble_gatts_attr_t    attr_char_value;
    ble_gatts_attr_md_t attr_md;
    // Add Custom Value characteristic
    memset(&cccd_md, 0, sizeof(cccd_md));
    //  Read  operation on cccd should be possible without authentication.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
    cccd_md.write_perm = p_cus_init->custom_value_char_attr_md.cccd_write_perm;
    cccd_md.vloc       = BLE_GATTS_VLOC_STACK;
    memset(&char_md, 0, sizeof(char_md));
    char_md.char_props.read   = 1;
    char_md.char_props.write  = 0;
    char_md.char_props.notify = 0;
    char_md.p_char_user_desc  = Str;
    char_md.char_user_desc_size = strlen(Str) ;
    char_md.char_user_desc_max_size = strlen(Str) ;
    char_md.p_char_pf         = NULL;
    char_md.p_user_desc_md    = NULL;
    char_md.p_cccd_md         = &cccd_md;
    char_md.p_sccd_md         = NULL;
    ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
    memset(&attr_md, 0, sizeof(attr_md));
    attr_md.read_perm  = p_cus_init->custom_value_char_attr_md.read_perm;
    attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
    attr_md.vloc       = BLE_GATTS_VLOC_STACK;
    attr_md.rd_auth    = 0;
    attr_md.wr_auth    = 0;
    attr_md.vlen       = 0;
    memset(&attr_char_value, 0, sizeof(attr_char_value));
    attr_char_value.p_uuid    = &ble_uuid;
    attr_char_value.p_attr_md = &attr_md;
    attr_char_value.init_len  = strlen(Str2);
    attr_char_value.init_offs = 0;
    attr_char_value.max_len   = strlen(Str2);
    attr_char_value.p_value   = Str2 ;
   err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
                                               &attr_char_value,
                                               &custom_value_handlex[p]);
        return err_code;
    return NRF_SUCCESS;
