Dear Nordic Team,
Thanks for supporting.
I want support for AES18bit Encription. Need basic tutorials and how to add my existing code.
Dear Nordic Team,
Please see the AES Example. If you want to encrypt advertisement data you need to do that in your application. Something like this might do the trick: https://devzone.nordicsemi.com/f/nordic-q-a/13429/aes-encryption-with-sd
-Amanda H.
Thanks for reply. I add AES128 encryption in my application (BLE_UART) both peripheral and central code. Peripheral side working good. But central side facing connection error.
0> <info> app: BLE UART central example started.
0> <info> app: C42CA8A1FD6A
0> <info> app: ATT MTU exchange completed.
0> <info> app: Ble NUS max data length set to 0xF4(244)
0> <info> app: Discovery complete.
0> <info> app: Connected to device with Nordic UART Service.
0> <info> peer_manager_handler: Connection security failed: role: Central, conn_handle: 0x0, procedure: Bonding, error: 4352
0> <warning> peer_manager_handler: Disconnecting conn_handle 0.
0> <info> app: Disconnected.
0> <info> app: Erase bonds
0> <info> peer_manager_handler: All peers deleted.
0> <error> app: Fatal error
My SDK 15.2
Example : ble_app_uart_c and ble_app_uart
please support solve this issue.
Hi Murugan,
Decimal 4352 is 0x1100. The following defines and reasoning for this error in peer_manager_types.h:
#define PM_CONN_SEC_ERROR_BASE 0x1000 /**< @brief The base for Peer Manager defined errors. See @ref PM_SEC_ERRORS and @ref pm_sec_error_code_t. */ #define PM_CONN_SEC_ERROR_DISCONNECT (PM_CONN_SEC_ERROR_BASE + 0x100) /**< @brief Pairing or encryption did not finish before the link disconnected for an unrelated reason. */
So it looks like the device disconnects before the pairing or encryption procedure completed.
Can you provide the full log output from the failing device? If you could set NRF_LOG_DEFAULT_LEVEL to 4 in your sdk_config.h file, that should provide more details.
What device are you testing against?
Can you provide a sniffer trace between the two devices when trying to perform bonding? You can use nRFSniffer v2 for that.
This thread might help.
-Amanda H.
Hi Murugan,
-Amanda H.
