How to set UART without CTS/RTS in Zigbee CLI example
I use Zigbee CLI example on nRF52840.
(examples\zigbee\experimental\cli\cli_agent_router)
It use UART as 115200 bps with CTS/RTS (hardware flow control).
I want to change setting UART to without CTS/RTS.
I looked in the project for the settings but couldn't find them.
Where should I set this up?
  • Hi
    In order to disable HW flow control you only need to set APP_UART_FLOW_CONTROL_DISABLED in the UART parameters and change the CTS and RTS pins in your application to NULL.
    Simon
  • Hi Simonr! Thank you for reply.
    I didn't know where to set "APP_UART_FLOW_CONTROL_DISABLED" up.
    Instead, I found the following.
    zigbee_cli.c:
    #if CLI_OVER_UART
    nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
    uart_config.pseltxd = TX_PIN_NUMBER;
    uart_config.pselrxd = RX_PIN_NUMBER;
    #if defined(HWFC) && (HWFC == true)
    uart_config.pselcts = CTS_PIN_NUMBER;
    uart_config.pselrts = RTS_PIN_NUMBER;
    uart_config.hwfc = NRF_UART_HWFC_ENABLED;
    ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_NONE);
    APP_ERROR_CHECK(ret);
    I changed to:
        uart_config.hwfc    =  NRF_UART_HWFC_DISABLED;
    So, I was able to get a CLI without RTS/CTS controls.
    But, The
    line are enabled. I don't know why HWCC is true. Where are you setting this up?
  • Hi
    Indeed, the zigbee_cli.c has enabled HWFC. Another file that enables the HWFC in the cli_agent_router app is in the nrfx_uart.c file. These should be the only places the HWFC is enabled in the cli_agent_router example.
    Simon
