I'm experimenting with NFC using HRM example.
Enabled my Android Phone NFC, programmed the example ( bonds clear ) .
First pair works - touch , get the "pair " , click Yes , I can see the device on the Bonded list.
From there -> NRF Connect -> Connect -> I can see the info from Device.
Now - From NRF Connect, I press disconnect.
1. Next "NFC Touch" Causes the program to run from scratch , why is that ? ( as if it was sleeping, and I touch to wake )
2. Now that device is awake - I'd like to reconnect to it, if I touch again -> I getting the "pair" message again on my phone. pressing yes will result in error 133.
( will work again only If I'm erasing bonds by starting with BTN 3 pressed )
So, what is going on ? I can I cause a paired device to start advertising again ? ( after a reset for ex. )
Ran
