I have trouble with interrupt.
I use pin 16 to trigger interrupt signals from a sx1261 module.
It has worked well on example code with SDK 14, but for my projet I have to migrate to SDK 15.2. Since migration I am not able to detect interrupts.
I have changed nrf_drv_spi and nrd_drv_gpiote drivers to nrfx drivers.
I think I missed a step while migrating project.
Do you have any idea of something wrong ?
Thank you
this is part of my project related with gpio interrupt:
GpioInit(&SX126x.DIO1, PIN_LORA_DIO_1, PIN_INPUT, PIN_PUSH_PULL, PIN_NO_PULL, 0);
GpioSetInterrupt(&SX126x.DIO1, IRQ_RISING_EDGE, IRQ_HIGH_PRIORITY, dioIrq);
static void gpiote_evt_handler (nrfx_gpiote_pin_t pin, nrf_gpiote_polarity_t unused)
if (GpioIrq[pin] != NULL)
GpioIrq[pin]();
void GpioInit (Gpio_t *obj, uint32_t pin, PinModes mode, PinConfigs config, PinTypes type, uint32_t value)
nrf_gpio_pin_pull_t pull_config;
if (pin >= NRF_NUM_GPIO_PINS)
return;
obj->pin = pin;
obj->pull = type;
if (mode == PIN_INPUT)
if (type == PIN_NO_PULL)
pull_config = NRF_GPIO_PIN_NOPULL;
else if (type == PIN_PULL_UP)
pull_config = NRF_GPIO_PIN_PULLUP;
else if (type == PIN_PULL_DOWN)
pull_config = NRF_GPIO_PIN_PULLDOWN;
nrf_gpio_cfg_input (obj->pin, pull_config);
else // mode output
nrf_gpio_cfg_output (obj->pin);
// Sets initial output value
if (mode == PIN_OUTPUT)
nrf_gpio_pin_write (pin, value);
void GpioSetInterrupt (Gpio_t *obj, IrqModes irqMode, IrqPriorities irqPriority, GpioIrqHandler *irqHandler)
uint32_t err_code;
if (obj->pin >= NRF_NUM_GPIO_PINS)
return;
if (irqHandler == NULL)
return;
GpioIrq[obj->pin] = irqHandler;
nrfx_gpiote_in_config_t gpiote_in_config;
gpiote_in_config.is_watcher = false;
gpiote_in_config.hi_accuracy = false;
// Check if gpiote lib is already initialized
// Initiliaze it if not
if (!nrfx_gpiote_is_init())
err_code = nrfx_gpiote_init();
// Configure pin number, polarity and pull configuration
nrfx_gpiote_pin_t pin = obj->pin;
if (irqMode == IRQ_RISING_EDGE)
gpiote_in_config.sense = NRF_GPIOTE_POLARITY_LOTOHI;
else if (irqMode == IRQ_FALLING_EDGE)
gpiote_in_config.sense = NRF_GPIOTE_POLARITY_HITOLO;
gpiote_in_config.sense = NRF_GPIOTE_POLARITY_TOGGLE;
if (obj->pull == PIN_NO_PULL)
gpiote_in_config.pull = NRF_GPIO_PIN_NOPULL;
else if (obj->pull == PIN_PULL_UP)
gpiote_in_config.pull = NRF_GPIO_PIN_PULLUP;
gpiote_in_config.pull = NRF_GPIO_PIN_PULLDOWN;
err_code = nrfx_gpiote_in_init (pin, &gpiote_in_config, gpiote_evt_handler);
nrfx_gpiote_in_event_enable(pin, true);
