i want to start evaluating FTP client in nrf9160 SoC. Can you provide an example code for FTP client mode.
Hi Praveen,
There is now a pull request open for the fixes:
https://github.com/nrfconnect/sdk-nrf/pull/2547
"Decouple Data and Control channel in FTP client for LIST and RETR
commands, leave the synchronization to SLM FTP code. This removes
the infinite wait as stated in problem 1.
No need of update for problem 2.
(the size of message is decided by FTP Server)"
NOTE-1: List a Get will now get Control message first, then Data message, then OK
NOTE-2: Data message by Get could be encoded as hexadecimal but there will be no indication of data type
Sample scenario:
Ready --> AT+CFUN=1 OK --> AT+CEREG? +CEREG: 5,1,"76C1","014ACE00",7,,,"11100000","00001111" OK --> AT#XFTP="open",,,"speedtest.tele2.net" 220 (vsFTPd 3.0.3) 200 Always in UTF8 mode. 331 Please specify the password. 230 Login successful. OK --> AT#XFTP="ls" 227 Entering Passive Mode (90,130,70,73,96,156). 150 Here comes the directory listing. 226 Directory send OK. 1000GB.zip 100GB.zip 100KB.zip 100MB.zip 10GB.zip 10MB.zip 1GB.zip 1KB.zip 1MB.zip 200MB.zip 20MB.zip 2MB.zip 3MB.zip 500MB.zip 50GB.zip 50MB.zip 512KB.zip 5MB.zip upload OK --> AT#XFTP="ls","-l" 227 Entering Passive Mode (90,130,70,73,110,27). 150 Here comes the directory listing. 226 Directory send OK. -rw-r--r-- 1 0 0 1073741824000 Feb 19 2016 1000GB.zip -rw-r--r-- 1 0 0 107374182400 Feb 19 2016 100GB.zip -rw-r--r-- 1 0 0 102400 Feb 19 2016 100KB.zip -rw-r--r-- 1 0 0 104857600 Feb 19 2016 100MB.zip -rw-r--r-- 1 0 0 10737418240 Feb 19 2016 10GB.zip -rw-r--r-- 1 0 0 10485760 Feb 19 2016 10MB.zip -rw-r--r-- 1 0 0 1073741824 Feb 19 2016 1GB.zip -rw-r--r-- 1 0 0 1024 Feb 19 2016 1KB.zip -rw-r--r-- 1 0 0 1048576 Feb 19 2016 1MB.zip -rw-r--r-- 1 0 0 209715200 Feb 19 2016 200MB.zip -rw-r--r-- 1 0 0 20971520 Feb 19 2016 20MB.zip -rw-r--r-- 1 0 0 2097152 Feb 19 2016 2MB.zip -rw-r--r-- 1 0 0 3145728 Feb 19 2016 3MB.zip -rw-r--r-- 1 0 0 524288000 Feb 19 2016 500MB.zip -rw-r--r-- 1 0 0 53687091200 Jul 24 2014 50GB.zip -rw-r--r-- 1 0 0 52428800 Feb 19 2016 50MB.zip -rw-r--r-- 1 0 0 524288 Feb 19 2016 512KB.zip -rw-r--r-- 1 0 0 5242880 Feb 19 2016 5MB.zip drwxr-xr-x 2 106 109 69632 Jul 02 09:22 upload OK --> AT#XFTP="binary" 200 Switching to Binary mode. OK --> AT#XFTP="ls","-l 1KB.zip" 227 Entering Passive Mode (90,130,70,73,93,53). 150 Here comes the directory listing. 226 Directory send OK. -rw-r--r-- 1 0 0 1024 Feb 19 2016 1KB.zip OK --> AT#XFTP="get","1KB.zip" 227 Entering Passive Mode (90,130,70,73,109,182). 226 Transfer complete. data connection for 1KB.zip (1024 bytes). 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 OK --> AT#XFTP="ls","-l 2KB.zip" 227 Entering Passive Mode (90,130,70,73,108,231). 150 Here comes the directory listing. 226 Directory send OK. OK --> AT#XFTP="get","2KB.zip" 227 Entering Passive Mode (90,130,70,73,108,196). ERROR
Here is the precompiled .hex with the fixes --> slm_ftp_02_07.hex
martin L.
Hi Martin,
I have tested the build shared "slm_ftp_02_07.hex" and found that now if file name is given wrong its not waiting for infinite time and returning error as shown below.
AT#XFTP="get","testtp.txt"
227 Entering Passive Mode (192,168,1,21,229,252).
ERROR
But if I read FTP status using AT command AT#XFTP="status" after getting response and then If I give any FTP command like to read a file from ftp server or given "ls" command or file name is given wrong, then again its going into infinite loop and not getting any response.
AT#XFTP="open","Administrator","Password1","192.168.1.21"
220 Microsoft FTP Service
200 OPTS UTF8 command successful - UTF8 encoding now ON.
331 Password required
230 User logged in.
OK
AT#XFTP="ls"
227 Entering Passive Mode (192,168,1,21,230,20).
150 Opening ASCII mode data connection.
testftp.txt
OK
AT#XFTP="get","testftp.txt"
227 Entering Passive Mode (192,168,1,21,230,26).
ata connection.
30,26).
ow ON.
Hello
OK
AT#XFTP="status"
215 Windows_NT
211-Microsoft FTP Service status:
Logged in user: Administrator
TYPE: ASCII; FORM: NONPRINT; STRUcture: FILE; transfer MODE: STREAM
Data connection: none
211 End of status.
OK
227 Entering Passive Mode (192,168,1,21,230,36).
"Got into infinite loop"
Can we minimize the extra messages for example came for connecting to FTP server using
230 User logged in.
Similar messages are also coming for other FTP commands- get,Ls, status
With regards,
Praveen P
Hi Praveen,
Sorry for the delay I have been out of office.
It looks like this has been addressed in the this PR:https://github.com/nrfconnect/sdk-nrf/commit/ffc175f41f0e4a731eae5496373d4a931146ffe0
It is merged with the master branch so if you update NCS and rebuild the application you should have the latest updates.
This version also includes the support to change UART baudrate: https://github.com/nrfconnect/sdk-nrf/pull/2571
Martin L.
