Serial LTE Modem SENDTO of hex string bigger than 32 bytes resets the module
I have been working with the Thingy:91 at the version 1.2.99 but this also happens on previous versions (I do not know which it was but the serial_lte_modem code had a at#xdatatype command that is no longer existing on version 1.2.0 or 1.2.99) of the SDK. In this version I am using the following functions to try to request a timestamp from an NTP server.
at#xsocket=1,2,0
#XSOCKET: 1, 2, 0, 17
OK
at#xbind=1024
OK
at#xsendto="178.32.88.247",123,0,"1b0000000000000000000000000000000000000000000000e2495ab3c7ae147800000000000000000000000000000000"
Ready
The "Ready" at the end means that the device has rebooted, I assume this is due to an error. This happens when the datatype is 0, which means hexadecimal string and the payload is more than 32 bytes,
which in a hex string would mean 64 bytes.
After doing a little bit of debugging I found out that the error may be in the handle_at_sendto(...) function of the slm_at_tcpip.c file, because I wrote a debugger to see what was inside the "data" vector
just before the line where it may be doing a segmentation error (line 1125). Inside my data vector I saw that there was my complete payload but there were additional strange characters such as '$' and 'É'.
Is there any other way to achieve this kind of communication (sending a hex string of this size) using the serial_lte_modem?
By the way, to communicate with the modem I have been using the LTE Link Monitor.
Thanks, Aleix.
  • The fix should be in master now. Please update the master repo ( git pull) and run west update. Then add the Config as instructed in my last comment.
    -Øyvind
  • Hi Øyvind,
    Adding CONFIG_SLM_UDP_PROXY=y in my prj.conf did not solve the problem, however, updating the repo did. Slight smile
    However, I think that the fix caused another different problem, where submitting an AT#RECVFROM command makes my Thingy:91 unresponsive to that and any other commands. The following image shows my execution: in this example I am using a command that I was able to execute successfully last week, which is a simple DNS look-up agaisnt Google servers.
    Maybe I should do some other checks, but in the meantime you get my feedback too.
    Thanks!
    Aleix.
  • Hi!
    Quick update, tried again. Waited a little bit longer before looking up for received bytes and it worked. I apologize for being so impacient yesterday!
    By the way, it is a little bit annoying that when I misspell a command I lose my ability to send commands to the module, similar to what happened there when I asked for the received bytes before they were actually there. Is there anything I can do besides trying to be pacient and be careful with my writing? haha
    Anyway, thanks for your help!
    Aleix
