nRF52840 DK lpcomp reads 0 (zero) no matter what voltage is applied to the input
I want to use a comparator without interrupt.
The measurement is not time critical.
Therefore, I chose the LPCOMP.
For initialization I use the following code:
static void lpcomp_init(uint8_t ref)
    nrf_lpcomp_config_t config;
    config.reference = (nrf_lpcomp_ref_t)ref;
    config.detection = NRF_LPCOMP_DETECT_CROSS;
    config.hyst      = LPCOMP_HYST_HYST_Hyst50mV;
    // config LPCOMP, from this point LPCOMP will be active
    nrf_lpcomp_configure(&config);
    nrf_lpcomp_input_select(PIN_REGENSENSOR);
    nrf_lpcomp_enable();
For reading the value I use the following code:
  uint8_t  lpcomp_result;
  nrf_lpcomp_task_trigger(NRF_LPCOMP_TASK_SAMPLE);
  lpcomp_result = (uint8_t)nrf_lpcomp_result_get();
Although the input is approximately VDD I get the value 0 back.
How can I use the LPCOMP (or COMP) without interrupts?
