SES import of SDK 10.0 examples ble_app_uart
I need to develop two applications for nRF51822 using SES version 4.18 (macOS). One is a DFU bootloader. The other is an application based on the ble_app_uart (ble_peripheral) example of SDK 10.0. I will be using SoftDevice 110 and I understand that SDK 10.0 is that latest version compatible with S110.
I've been following this blog post to import a Keil project. Seems it is written for nRF52 development using an older version of SES (v3.10e) and is, therefore, inaccurate in some ways.
I would be grateful for some assistance in importing/building the ble_app_uart example from SDK 10.0 into SES.
The first step asks to install the CMSIS-CORE Support Package. In SES 4.18, it appears this package is already installed.
After importing the file nRF51SDK/examples/ble_peripheral/ble_app_uart/pca10028/s110/arm5_no_packs/ble_app_uart_s110_pca10028.uvprojx, I see a project configuration named nrf51422_xxac_s110. As I am developing for nRF51822, I wonder about additional project configuration changes needed? I understand that the nRF51422 is an nRF51822 with ANT support. I will be developing/testing with an nRF51 DK.
In the section Adding nRF5 MDK Files ...
I create embedded_studio folder inside nRF51SDK/components/toolchain.
I download ses_nrf51_startup.s and ses_nrf52_startup.s and save them into nRF51SDK/components/toolchain/embedded_studio/
When I download ses_nrf51_startup.s and ses_nrf52_startup.s, they download as 3324.ses_nrf51_startup.s and 5543.ses_nrf52_startup.s. I rename to ses_nrf51_startup.s and ses_nrf52_startup.s.
I remove Cortex_M_Startup.s from Internal Files in project explorer.
I notice that the remaining file in Internal Files is SEGGER_THUMB_Startup.s and I do not see thumb_crt0.s.
Next instructed to add NRF5_SDK/components/toolchain/system_nrf52.c to Internal Files. I assume that since I'm importing a project for nRF51, I should add system_nrf51.c instead, which I do. Same for NRF5_SDK/components/toolchain/embedded_studio/ses_nrf52_startup.s - I add ses_nrf51_startup.s instead.
As instructed, I add ../../../../../../components/device to the Preprocessor User Include Directories, which results in the following:
../../../config
../../../../../bsp
../../../../../../components/toolchain
../../../../../../components/ble/ble_advertising
../../../../../../components/ble/ble_services/ble_nus
../../../../../../components/ble/common
../../../../../../components/drivers_nrf/common
../../../../../../components/drivers_nrf/delay
../../../../../../components/drivers_nrf/gpiote
../../../../../../components/drivers_nrf/hal
../../../../../../components/drivers_nrf/pstorage
../../../../../../components/drivers_nrf/uart
../../../../../../components/drivers_nrf/config
../../../../../../components/libraries/button
../../../../../../components/libraries/fifo
../../../../../../components/libraries/timer
../../../../../../components/libraries/trace
../../../../../../components/libraries/uart
../../../../../../components/libraries/util
../../../../../../components/softdevice/common/softdevice_handler
../../../../../../components/softdevice/s110/headers
It appears that Peer Manager/Flash Data Storage applies if the application uses Peer Manager. It appears that ble_app_uart example of SDK 10.0 does not use Peer Manager, so I'm not sure if any of the instructions in Peer Manager/Flash Data Storage apply.
I see no flash_placement.xml file inside nRF51SDK/examples/ble_peripheral/ble_app_uart/pca10028/s110/arm5_no_packs. Do I still need to create this file?
I do see thumb_crt0.s inside SEGGER_app_folder/source, but not sure if the changes for fs_data should be added. I presume no.
I notice that there's no sdk_config.h file and appears this file was added to the SDK architecture after SDK 10.0?
So I do NOT do any of the steps in Peer Manager/Flash Data Storage and proceed to attempt to build the application. I got the compile error "nrf.h No such file or directory". I found that this file exists inside nRF51SDK/components/toolchain/gcc so I added that to the User Include Directories and build proceeds but then I get the compile error seen in attached compile log. I'm now lost.
Appreciate any assistance to getting ble_app_uart (ble_peripheral) of SDK 10.0 successfully imported/built for nRF51 DK (compatible with nRF51822).
I see that using S130 would mean I could use SDK 12.3 instead of 10.0. All my application needs is basic peripheral support plus access to the Timeslot API. I presume S130 would add unnecessary capabilities and size, so would prefer to stick with S110 and SDK 10.0.
Many thanks,
Tim
  • Tim said:
    I found this post but don't understand exactly what needs to be added to memory segments. How can I learn about this?
    I don't know how this works in SES. I can only point to the later SDKs, and the flash section placement in those examples. You need to port that to your project.
    Try to open an bootloader example from SDK16, and click "Edit Section Placement". You should see something like this:
    But it looks like you got this message in the application, and not the bootloader, is that correct? I can't see any reference to the bootloader settings page in the ble_app_buttonless from SDK16...
    The graceful shutdown is nice to have, but not mandatory. It is just to give the application time to disconnect all connections, finish ongoing flash operations and so on before suddenly cutting the power. If you only have one connection, you don't need to worry about this (as long as you don't do any proprietary flash operations that can take damage from power cuts. FDS should be able to handle this by itself.
    BR,
    Edvin
  • Hi Edvin. Correct, it’s ble_app_uart that I’m getting build errors after extending to support buttonless dfu.
    It looks like it's something to do with adding a second service in services_init(). I add this code:
        ble_dfu_init_t dfus_init;
        // Initialize the Device Firmware Update Service.
        memset(&dfus_init, 0, sizeof(dfus_init));
        dfus_init.evt_handler                               = ble_dfu_evt_handler;
        dfus_init.ctrl_point_security_req_write_perm        = SEC_SIGNED;
        dfus_init.ctrl_point_security_req_cccd_write_perm   = SEC_SIGNED;
        err_code = ble_dfu_init(&m_dfus, &dfus_init);
        //APP_ERROR_CHECK(err_code);
    and the link error now occurs.
    Building ‘ble_app_uart_pca10028_s130’ from solution ‘ble_app_uart_pca10028_s130’ in configuration ‘Debug’
      Compiling ‘main.c’
      Linking ble_app_uart_pca10028_s130.elf
        Output/Debug/Exe/ble_app_uart_pca10028_s130.elf section `.bootloaderSettings' will not fit in region `UNPLACED_SECTIONS'
        region `UNPLACED_SECTIONS' overflowed by 1024 bytes
    Build failed
    If I comment out:
    it builds successfully. I've read that when you increase the number of ble services, you need to change RAM start and size to allow more memory for the SoftDevice. Add 16 to the RAM start address and subtract 16 from the size. I understand you do this with project -> options -> Linker -> section placement macros. Current values are:
    I tried changing RAM_START to 0x20001ff8 and RAM_SIZE to 0x2008, but still link error.
    I'm using this flash_placement.xml file:
    <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
        <ProgramSection load="no" name=".reserved_flash" start="$(FLASH_PH_START)" size="$(FLASH_START)-$(FLASH_PH_START)" />
        <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
        <ProgramSection alignment="4" load="Yes" name=".init" />
        <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
        <ProgramSection alignment="4" load="Yes" name=".text" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_soc_observers" inputsections="*(SORT(.sdh_soc_observers*))" address_symbol="__start_sdh_soc_observers" end_symbol="__stop_sdh_soc_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ble_observers" inputsections="*(SORT(.sdh_ble_observers*))" address_symbol="__start_sdh_ble_observers" end_symbol="__stop_sdh_ble_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_req_observers" inputsections="*(SORT(.sdh_req_observers*))" address_symbol="__start_sdh_req_observers" end_symbol="__stop_sdh_req_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_state_observers" inputsections="*(SORT(.sdh_state_observers*))" address_symbol="__start_sdh_state_observers" end_symbol="__stop_sdh_state_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_stack_observers" inputsections="*(SORT(.sdh_stack_observers*))" address_symbol="__start_sdh_stack_observers" end_symbol="__stop_sdh_stack_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_command" inputsections="*(.cli_command*)" address_symbol="__start_cli_command" end_symbol="__stop_cli_command" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data"  inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data"  inputsections="*(.fs_data*)" runin=".fs_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_sorted_cmd_ptrs"  inputsections="*(.cli_sorted_cmd_ptrs*)" runin=".cli_sorted_cmd_ptrs_run"/>
        <ProgramSection alignment="4" load="Yes" name=".dtors" />
        <ProgramSection alignment="4" load="Yes" name=".ctors" />
        <ProgramSection alignment="4" load="Yes" name=".rodata" />
        <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
        <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
        <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
        <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
      </MemorySegment>
      <MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
        <ProgramSection load="no" name=".reserved_ram" start="$(RAM_PH_START)" size="$(RAM_START)-$(RAM_PH_START)" />
        <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".cli_sorted_cmd_ptrs_run" address_symbol="__start_cli_sorted_cmd_ptrs" end_symbol="__stop_cli_sorted_cmd_ptrs" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" />
        <ProgramSection alignment="4" load="No" name=".fast_run" />
        <ProgramSection alignment="4" load="No" name=".data_run" />
        <ProgramSection alignment="4" load="No" name=".tdata_run" />
        <ProgramSection alignment="4" load="No" name=".bss" />
        <ProgramSection alignment="4" load="No" name=".tbss" />
        <ProgramSection alignment="4" load="No" name=".non_init" />
        <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
        <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack"  address_symbol="__StackLimit" end_symbol="__StackTop"/>
        <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
      </MemorySegment>
    </Root>
    Oh, and I also added this line:
    ble_enable_params.common_enable_params.vs_uuid_count = 2;
    to ble_stack_init():
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize SoftDevice.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        err_code = softdevice_enable(&ble_enable_params);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
        // Register with the SoftDevice handler module for BLE events.
        err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
    Appreciate your help Edvin. Many thanks,
    Tim
  • Hi Edvin. More info. I found this post and added to flash_placement.xml:
    <ProgramSection alignment="4" load="Yes" name=".bootloaderSettings" start="$(BOOTLOADER_SETTINGS_START:0x0003FC00)" size="$(BOOTLOADER_SETTINGS_SIZE:0x400)" />
    Now get the following build log:
      Generating linker script ‘ble_app_uart_pca10028_s130.ld’
        .bootloaderSettings is too large to fit in RAM memory segment
        section .stack_process overlaps absolute placed section .bootloaderSettings
    Build failed
    Tim
  • Try setting the bootloader settings to START: 0x3F000 and SIZE: 0x1000
  • Hi Edvin. Thanks for this. I'll try your suggestion shortly. I've recently learned a couple things. First, apparently I cannot update Simblee's Legacy DFU bootloader (over BLE) with the Secure Bootloader of SDK 12.3 because it has a larger flash footprint. I could only update the Legacy DFU bootloader to another of the same that I compile. That could be helpful because I would then have control of the SoftDevice used.
    The bootloader on Simblee is dual bank which limits the size of any image updated. Not enough space to update bootloader and SoftDevice.
    Thankfully, I learned that Simblee uses SoftDevice 110 v8.0.0. The Simblee Legacy DFU bootloader will accept images containing applications that use s110 v8.0.0. It feels like a way forward is to develop our application for Simblee to use s110 v8.0.0 with SDK 12.3. I need to learn how to add s110 v8.0.0 to SDK 12.3 and then change the ble_app_uart I have building for s130 to use s110 instead. Will start this work in the next couple days.
    Many thanks Edvin.
    Tim
