SDK: NRF 5 15.3
SoftDevice: S140
I have been successfully using the NUS code snippet below to send data periodically to my expensive Smartphone running Android 10 (fast device) from my peripheral. I am seeing issues when using a cheaper tablet running Android 9 (slow device).
// Loop while sending samples from the acc ramstore.
while(samples_left > 0)
// Send up to 40 samples at a time (40x6=240 bytes .. fits within BLE packet with minimal waste).
if(samples_left > 40) { samples_send = 40; }
else { samples_send = samples_left; }
//SEGGER_RTT_printf(0, "Samples left %d\n", samples_left);
// Get byte length from samples.
resp_len_bytes = samples_send * 6;
// Setup additional response header bytes.
resp_bytes[1] = (uint8_t) resp_len_bytes;
resp_bytes[2] = BLE_SUCCESS;
// Update payload.
memcpy(&(resp_bytes[3]), &(xtag_get_acc_ramstore_ptr()[samples_sent]), resp_len_bytes);
// Send.
do { err_code = ble_nus_data_send(&m_nus, resp_bytes, &resp_len_bytes, m_conn_handle); }
while (err_code == NRF_ERROR_RESOURCES);
// Inc samples_sent.
samples_sent += samples_send;
// Dec samples_left based on the number of samples sent.
samples_left -= samples_send;
The while loop is called every 16, 32 or 64 mSec (timer handler) depending on how fast I pull data from my accelerometer (acc). About 150 bytes (25 samples) are sent within each handler call. I have setup 2M phy and 244 byte MTU. No issues on either setting as their negotiation with Android seems to be fine for both fast and slow Android devices. On the slow device, I am not seeing an issue when the handler is called every 64 mS, and I rarely see an issue at 32 mS, but I always see an issue at 16 mS handler period. The issue shows up in 1 of 2 ways.
1. The code gets stuck in the while loop. Its test condition never fails because the ble_nus_data_send() gets stuck returning NRF_ERROR_RESOURCES constantly.
2. I get a fault and the SES Studio Debug terminal shows:
!!!!!!!! - Critical Fault - !!!!!!!!!!! ERROR 19 [NRF_ERROR_RESOURCES] at :0 PC at: 0x00000000 End of error report System reseting ....
I do not need to support fast data (16 and 32 mSec handler periods) on the slow device, but I do need to handle the 2 issues listed above more gracefully (if a any slow central device connects to my peripheral). I cannot have my firmware stuck in a loop or faulting out.
Please advise how I can handle my slow device comms errors more effectively to ensure my peripheral does not hang or restart.
Thanks in advance.
Mark J
