PPI to SWI/EGU connection
SDK: 15.2
IDE: Keil
Softdevice: S132 v 6.0
General question about PPI connections.  Is it possible to setup a PPI channel, that when triggered by some event (e.g. value in RTC counter matches compare register CC[0]), triggers a software interrupt/handler where I can run some code?
E
  • Yes, this is possible. I have put together a simple example if you want to test it out:
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup blinky_example_main main.c
     * @ingroup blinky_example
     * @brief Blinky Example Application main file.
     * This file contains the source code for a sample application to blink LEDs.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf_delay.h"
    #include "boards.h"
    void SWI0_EGU0_IRQHandler(void)
        /* Clear event register */
        NRF_EGU0->EVENTS_TRIGGERED[0] = 0;
        bsp_board_led_invert(BSP_BOARD_LED_0);
    /* Start LF clock source for RTC */
    void clock_init()
        NRF_CLOCK->LFCLKSRC = CLOCK_LFCLKSTAT_SRC_Xtal << CLOCK_LFCLKSTAT_SRC_Pos;
        NRF_CLOCK->TASKS_LFCLKSTART = 1;
        while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
    void rtc_init()
        NRF_RTC2->CC[0] = 32768;
        /* Event signal must be enabled explicitly unlike most other peripherals */
        NRF_RTC2->EVTENSET = RTC_EVTEN_COMPARE0_Msk;
        NRF_RTC2->TASKS_START = 1;
    void ppi_interrupt_init()
        /* 6 is the default int. priority used in SDK drivers */
        NVIC_SetPriority(SWI0_EGU0_IRQn, 6);
        NVIC_EnableIRQ(SWI0_EGU0_IRQn);
        NRF_EGU0->INTENSET = EGU_INTEN_TRIGGERED0_Msk;
        NRF_PPI->CH[0].EEP = (uint32_t) &NRF_RTC2->EVENTS_COMPARE[0];
        NRF_PPI->CH[0].TEP = (uint32_t) &NRF_EGU0->TASKS_TRIGGER[0];
        /* RTC does not have a SHORT to clear counter on compare match
           so using PPI instead */
        NRF_PPI->FORK[0].TEP = (uint32_t) &NRF_RTC2->TASKS_CLEAR;
        NRF_PPI->CHENSET = PPI_CHENSET_CH0_Msk;
     * @brief Function for application main entry.
        /* Configure board. */
        clock_init();
        rtc_init();
        ppi_interrupt_init();
        /* Wait for interrupts */
        while (true)
           __WFI();
    The example is configured to toggle a LED from the EGU0 ISR once every second.
