NRF52840 change publication address error
I am using nRF Mesh SDK 4.1 and nrf SDK 16. I started with the light switch client example on a DevKit.
I am trying to change the publication address of the client because i will have 50+ servers and dont want to create 50+ models on the client. The address to set bill be sent over UART, which i have correctly implemented.
This is my function to change the publication address:
static void change_publication_address(access_model_handle_t handle, uint16_t address)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Change Publication address\n"); // This is still printed out on the RTT viewer
    uint32_t status = NRF_SUCCESS;
    nrf_mesh_address_t publish_address_stored;
    destination_address = address;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "entering function\n");
    if(publish_address_handle != DSM_HANDLE_INVALID)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Try Removing last publish address\n");
        NRF_MESH_ASSERT(dsm_address_publish_remove(publish_address_handle) == NRF_SUCCESS);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Removing last publish address\n");
    if(access_model_publish_address_get(handle, &publish_address_handle) == NRF_SUCCESS)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "1\n");
        status = dsm_address_publish_add(destination_address, &publish_address_handle);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "adding new publication address1\n");
        if(dsm_address_get(publish_address_handle, &publish_address_stored) == NRF_SUCCESS)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "2\n");
            if((publish_address_stored.type == NRF_MESH_ADDRESS_TYPE_VIRTUAL)||(publish_address_stored.type != NRF_MESH_ADDRESS_TYPE_VIRTUAL && publish_address_stored.value != destination_address))
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "3\n");
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "adding new publication address2\n");
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "4\n");
                // use the retrieved publish_address_handle
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "5\n");
            status = dsm_address_publish_remove(publish_address_handle);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "adding new publication address3\n");
    switch(status)
        case NRF_ERROR_NO_MEM:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NRF_ERROR_NO_MEM\n");
            return;
        case NRF_SUCCESS:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NRF_SUCCESS\n");
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Not defined ERROR\n");
            return;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "6\n");
    NRF_MESH_ASSERT(access_model_publish_address_set(handle, publish_address_handle) == NRF_SUCCESS);  // change the address
I call this function like follows:
static dsm_handle_t publish_address_handle = DSM_HANDLE_INVALID; // defined at the top of main.c
uint16_t my_address = 0x0003;
change_publication_address(m_clients[0].model_handle, my_address);
This should change the publication address of the Generic On Off Client to 0x0003.
However, this is what I get as output:
Which leads me to believe that something's wrong with the publish_address_handle.
From This I can see that the error has to be in status = dsm_address_publish_add(destination_address, &publish_address_handle); , since the next __LOG is not output.
If i go into this function and then into the add_address() function, I see that the error must happen in the function dsm_entry_store(MESH_OPT_DSM_NONVIRTUAL_ADDR_RECORD, handle, m_addr_nonvirtual_allocated); (also checked this out with __LOG).
I also tried a different set_model_publish_address() function which i found here on DevZone:
static uint32_t set_model_publish_address(uint16_t publish_address, access_model_handle_t model_handle) {
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "7\n");
  NRF_MESH_ASSERT(access_model_publish_address_get(model_handle, &publish_address_handle) == NRF_SUCCESS);
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "8\n");
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "9\n");
  status = dsm_address_publish_add(publish_address, &publish_address_handle);
  __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "10\n");
  if (status != NRF_SUCCESS) {
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "11\n");
    return status;
  } else {
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "12\n");
    return access_model_publish_address_set(model_handle, publish_address_handle);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "13\n");
I call this function as before with set_model_publish_address(my_address, m_clients[0].model_handle);
The output here is:
The output '18' means that the function dsm_address_publish_remove() in device_state_manager.c returns NRF_ERROR_NOT_FOUND;
In both cases, all the LEDs on my DevKit go on. I tried it whit my DK provisioned and unprovisioned, still the same problem. Here's the complete main.c:
/* Copyright (c) 2010 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
 * list of conditions and the following disclaimer.
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Models */
#include "generic_onoff_client.h"
#include "generic_onoff_server.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "example_common.h"
#include "app_onoff.h"
#include "ble_softdevice_support.h"
/* UART stuff */
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
static uint16_t destination_address;                // global destination address variable
 * SERVER config
 * Definitions
#define ONOFF_SERVER_0_LED          (BSP_LED_0)
#define APP_ONOFF_ELEMENT_INDEX     (0)
/* Controls if the model instance should force all mesh messages to be segmented messages. */
#define APP_FORCE_SEGMENTATION      (false)
/* Controls the MIC size used by the model instance for sending the mesh messages. */
#define APP_MIC_SIZE                (NRF_MESH_TRANSMIC_SIZE_SMALL)
 * Forward declaration of static functions
static void app_onoff_server_set_cb(const app_onoff_server_t * p_server, bool onoff);
static void app_onoff_server_get_cb(const app_onoff_server_t * p_server, bool * p_present_onoff);
static void app_onoff_server_transition_cb(const app_onoff_server_t * p_server,
                                                uint32_t transition_time_ms, bool target_onoff);
 * Static variables
static bool m_device_provisioned;
/* Generic OnOff server structure definition and initialization */
APP_ONOFF_SERVER_DEF(m_onoff_server_0,
                     APP_FORCE_SEGMENTATION,
                     APP_MIC_SIZE,
                     app_onoff_server_set_cb,
                     app_onoff_server_get_cb,
                     app_onoff_server_transition_cb)
/* Callback for updating the hardware state */
    /* Resolve the server instance here if required, this example uses only 1 instance. */
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting GPIO value: %d\n", onoff)
    hal_led_pin_set(ONOFF_SERVER_0_LED, onoff);
/* Callback for reading the hardware state */
    *p_present_onoff = hal_led_pin_get(ONOFF_SERVER_0_LED);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Transition time: %d, Target OnOff: %d\n",
                                       transition_time_ms, target_onoff);
static void app_model_init(void)
    /* Instantiate onoff server on element index APP_ONOFF_ELEMENT_INDEX */
    ERROR_CHECK(app_onoff_init(&m_onoff_server_0, APP_ONOFF_ELEMENT_INDEX));
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App OnOff Model Handle: %d\n", m_onoff_server_0.server.model_handle);
 * Definitions
#define APP_STATE_OFF                (0)
#define APP_STATE_ON                 (1)
#define APP_UNACK_MSG_REPEAT_COUNT   (2)
/* Delay value used by the OnOff client for sending OnOff Set messages. */
#define APP_ONOFF_DELAY_MS           (50)
/* Transition time value used by the OnOff client for sending OnOff Set messages. */
#define APP_ONOFF_TRANSITION_TIME_MS (100)
static void app_gen_onoff_client_publish_interval_cb(access_model_handle_t handle, void * p_self);
static void app_generic_onoff_client_status_cb(const generic_onoff_client_t * p_self,
                                               const access_message_rx_meta_t * p_meta,
                                               const generic_onoff_status_params_t * p_in);
static void app_gen_onoff_client_transaction_status_cb(access_model_handle_t model_handle,
                                                       void * p_args,
                                                       access_reliable_status_t status);
 * Static variables
static generic_onoff_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
const generic_onoff_client_callbacks_t client_cbs =
    .onoff_status_cb = app_generic_onoff_client_status_cb,
    .ack_transaction_status_cb = app_gen_onoff_client_transaction_status_cb,
    .periodic_publish_cb = app_gen_onoff_client_publish_interval_cb
static void device_identification_start_cb(uint8_t attention_duration_s)
    hal_led_mask_set(LEDS_MASK, false);
    hal_led_blink_ms(BSP_LED_2_MASK  | BSP_LED_3_MASK,
                     LED_BLINK_ATTENTION_INTERVAL_MS,
                     LED_BLINK_ATTENTION_COUNT(attention_duration_s));
static void provisioning_aborted_cb(void)
    hal_led_blink_stop();
static void unicast_address_print(void)
    dsm_local_unicast_address_t node_address;
    dsm_local_unicast_addresses_get(&node_address);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
static void provisioning_complete_cb(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
#if MESH_FEATURE_GATT_ENABLED
    /* Restores the application parameters after switching from the Provisioning
     * service to the Proxy  */
    gap_params_init();
    conn_params_init();
    unicast_address_print();
    hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
/* This callback is called periodically if model is configured for periodic publishing */
     __LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Publish desired message here.\n");
/* Acknowledged transaction status callback, if acknowledged transfer fails, application can
* determine suitable course of action (e.g. re-initiate previous transaction) by using this
* callback.
                                                       void * p_args,
    switch(status)
        case ACCESS_RELIABLE_TRANSFER_SUCCESS:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer success.\n");
        case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
            hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer timeout.\n");
        case ACCESS_RELIABLE_TRANSFER_CANCELLED:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer cancelled.\n");
            ERROR_CHECK(NRF_ERROR_INTERNAL);
/* Generic OnOff client model interface: Process the received status message in this callback */
    if (p_in->remaining_time_ms > 0)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d, Target OnOff: %d, Remaining Time: %d ms\n",
              p_meta->src.value, p_in->present_on_off, p_in->target_on_off, p_in->remaining_time_ms);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d\n",
              p_meta->src.value, p_in->present_on_off);
static void node_reset(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
    /* This function may return if there are ongoing flash operations. */
    mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
    if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
        node_reset();
#if NRF_MESH_LOG_ENABLE
static const char m_usage_string[] =
    "\n"
    "\t\t------------------------------------------------------------------------------------\n"
    "\t\t Button/RTT 1) Send a message to the odd group (address: 0xC003) to turn on LED 1.\n"
    "\t\t Button/RTT 2) Send a message to the odd group (address: 0xC003) to turn off LED 1.\n"
    "\t\t Button/RTT 3) Send a message to the even group (address: 0xC002) to turn on LED 1.\n"
    "\t\t Button/RTT 4) Send a message to the even group (address: 0xC002) to turn off LED 1.\n"
    "\t\t------------------------------------------------------------------------------------\n";
static void button_event_handler(uint32_t button_number)
    /* Increase button number because the buttons on the board is marked with 1 to 4 */
    button_number++;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
    generic_onoff_set_params_t set_params;
    model_transition_t transition_params;
    static uint8_t tid = 0;
    switch(button_number)
        case 1:
        case 3:
            set_params.on_off = APP_STATE_ON;
        case 2:
        case 4:
            set_params.on_off = APP_STATE_OFF;
    set_params.tid = tid++;
    transition_params.delay_ms = APP_ONOFF_DELAY_MS;
    transition_params.transition_time_ms = APP_ONOFF_TRANSITION_TIME_MS;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
    switch (button_number)
        case 1:
        case 2:
            /* Demonstrate acknowledged transaction, using 1st client model instance */
            /* In this examples, users will not be blocked if the model is busy */
            (void)access_model_reliable_cancel(m_clients[0].model_handle);
            status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
            hal_led_pin_set(BSP_LED_0, set_params.on_off);
            //printf("UART test ");
        case 3:
        case 4:
            /* Demonstrate un-acknowledged transaction, using 2nd client model instance */
            status = generic_onoff_client_set_unack(&m_clients[1], &set_params,
                                                    &transition_params, APP_UNACK_MSG_REPEAT_COUNT);
            hal_led_pin_set(BSP_LED_1, set_params.on_off);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
    switch (status)
        case NRF_SUCCESS:
        case NRF_ERROR_BUSY:
        case NRF_ERROR_INVALID_STATE:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %u cannot send\n", button_number);
        case NRF_ERROR_INVALID_PARAM:
            /* Publication not enabled for this client. One (or more) of the following is wrong:
             * - An application key is missing, or there is no application key bound to the model
             * - The client does not have its publication state set
             * It is the provisioner that adds an application key, binds it to the model and sets
             * the model's publication state.
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %u\n", button_number);
            ERROR_CHECK(status);
static void rtt_input_handler(int key)
    if (key >= '1' && key <= '4')
        uint32_t button_number = key - '1';
        button_event_handler(button_number);
static void models_init_cb(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "adding server model\n");
    app_model_init();
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
    for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i)
        m_clients[i].settings.p_callbacks = &client_cbs;
        m_clients[i].settings.timeout = 0;
        m_clients[i].settings.force_segmented = APP_FORCE_SEGMENTATION;
        m_clients[i].settings.transmic_size = APP_MIC_SIZE;
        ERROR_CHECK(generic_onoff_client_init(&m_clients[i], i + 1));
static void mesh_init(void)
    mesh_stack_init_params_t init_params =
        .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
        .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
        .core.p_uuid             = NULL,
        .models.models_init_cb   = models_init_cb,
        .models.config_server_cb = config_server_evt_cb
    uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
    switch (status)
        case NRF_ERROR_INVALID_DATA:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
			__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reset device before start provisioning.\n");
        case NRF_SUCCESS:
 * Change publication address
    switch(status)
            return;
        case NRF_SUCCESS:
            return;
//This code below did not work at all, it crashed the server somehow
    return status;
  } else {
 * UART
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
/* When UART is used for communication with the host do not use flow control.*/
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
    static uint8_t data_array[20];
    //static uint8_t index = 0;
    uint32_t  err_code;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "UART Event\n");
    switch(p_event->evt_type)
        case APP_UART_DATA_READY:
            app_uart_get(&data_array[0]);
            //index++;
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "UART Data received: ------------- %x\n", data_array[0]);
            if(data_array[0] == 0x61) // When i send an 'a' from my Python terminal. This is working
                //my_address = 0x0003;
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "0x61 pressed, blinking LEDs ------------- \n");
                //change_publication_address(m_clients[0].model_handle, my_address); // This is called correctly
            if(data_array[0] == 0x62) // When i send a 'b' from my Python terminal. This is working
                my_address = 0x0002;
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "0x62 pressed, blinking LEDs ------------- \n");
                set_model_publish_address(0x0002, m_clients[0].model_handle);
        case APP_UART_FIFO_ERROR:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Undifinded UART Handle state\n");
void uart_init(void)
uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
          NRF_UART_BAUDRATE_115200
#else
          NRF_UARTE_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_event_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
 * LOCAL CONFIGURATION OF MESH FUNCTIONS
static void initialize(void)
    __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
    ERROR_CHECK(app_timer_init());
    hal_leds_init();
#if BUTTON_BOARD
    ERROR_CHECK(hal_buttons_init(button_event_handler));
    ble_stack_init();
    gap_params_init();
    conn_params_init();
    mesh_init();
static void start(void)
    rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
    if (!m_device_provisioned)
        static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
        mesh_provisionee_start_params_t prov_start_params =
            .p_static_data    = static_auth_data,
            .prov_sd_ble_opt_set_cb = NULL,
            .prov_complete_cb = provisioning_complete_cb,
            .prov_device_identification_start_cb = device_identification_start_cb,
            .prov_device_identification_stop_cb = NULL,
            .prov_abort_cb = provisioning_aborted_cb,
            .p_device_uri = EX_URI_LS_CLIENT
        ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
    mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
    ERROR_CHECK(mesh_stack_start());
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
    initialize();
    start();
    uart_init();
    for (;;)
        (void)sd_app_evt_wait();
I hope someone can help.
Thank you
