GNU GCC Stack and Heap Size Issues
The end of memory bss is @ 0x20002DAC (11692B). The start of the heap is @ 0x20002DB0 with a size of 2560B. The heap ends at 0x200037B0. The stack works back from the end 0x20004000 to 0x20003800 (14336B).
So there should be enough room and I should be able to allocate 2560B....?
BUT,
I have written two routines to check the stack and heap.
The stack checks memory for 0xDEADBEEF. This gives: Stack=1596B
That iterates through increasing block sizes (16B) until the heap fails. This gives: Heap=576B
So what am I missing?
And whats this object doing in the heap?
0x20002db0 0xa00 build/gcc_startup_nrf51.o
Is it overflow, and If so why does the compiler not complain and how can I get it to be more verbose about problems like this?
LINKER SCRIPT (NORDIC GCC) - Relevant code of the script:
    .syntax unified
    .arch armv6-m
    .section .stack
    .align 3
    .equ    Stack_Size, 2048
    .globl    __StackTop
    .globl    __StackLimit
__StackLimit:
    .space    Stack_Size
    .size __StackLimit, . - __StackLimit
__StackTop:
    .size __StackTop, . - __StackTop
    .section .heap
    .align 3
    .equ    Heap_Size, 2560
    .globl    __HeapBase
    .globl    __HeapLimit
__HeapBase:
    .if    Heap_Size
    .space    Heap_Size
    .endif
    .size __HeapBase, . - __HeapBase
__HeapLimit:
    .size __HeapLimit, . - __HeapLimit
MAP FILE - Relevant output of the map file:
.bss           0x20001da8        0x0 ../../tools/gccarm/arm-none-eabi/lib/armv6-m\libnosys.a(_exit.o)
 *(COMMON)
 COMMON         0x20001da8     0x1000 build/fifo.o
                0x20001da8                uFifoTxMem
                0x200025a8                uFifoRxMem
 COMMON         0x20002da8        0x4 ../../tools/gccarm/arm-none-eabi/lib/armv6-m\libc.a(lib_a-reent.o)
                0x20002da8                errno
                0x20002dac                . = ALIGN (0x4)
                0x20002dac                __bss_end__ = .
.heap           0x20002db0      0xa00
                0x20002db0                __end__ = .
                0x20002db0                end = __end__
 *(.heap*)
 .heap          0x20002db0      0xa00 build/gcc_startup_nrf51.o
                0x20002db0                __HeapBase
                0x200037b0                __HeapLimit = .
.stack_dummy    0x20002db0      0x800
 *(.stack*)
 .stack         0x20002db0      0x800 build/gcc_startup_nrf51.o
                0x20004000                __StackTop = (ORIGIN (RAM) + 0x3ff8)
                0x20003800                __StackLimit = (__StackTop - SIZEOF (.stack_dummy))
                0x20004000                PROVIDE (__stack, __StackTop)
                0x00000001                ASSERT ((__StackLimit >= __HeapLimit), region RAM overflowed with stack)
OUTPUT(build/main_xxab.out elf32-littlearm)
