I'm trying to setup interrupt routines in SPIS1 peripheral.
I have a void IRQ function
void SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQHandler(void)
if (NRF_SPIS1->EVENTS_ACQUIRED)
NRF_SPIS1->EVENTS_ACQUIRED = 0x0UL;
spis_set_tx_buffer(tx_buffer, strlen(tx_buffer));
spis_set_rx_buffer(rx_buffer, sizeof(rx_buffer));
NRF_SPIS1->TASKS_RELEASE = true;
if (NRF_SPIS1->EVENTS_END)
NRF_SPIS1->EVENTS_END = 0x0UL;
NRF_SPIS1->TASKS_ACQUIRE = true;
if (NRF_SPIS1->EVENTS_ENDRX)
NRF_SPIS1->EVENTS_ENDRX = 0x0UL;
But it seems like it never gets called
my init function
void spis_init(void)
spis_pins_init();
spis_set_tx_buffer(NULL, 0);
spis_set_rx_buffer(NULL, 0);
spis_configure();
spis_def_set(0xFF);
spis_orc_set(0xFF);
spis_shorts_enable(SPIS_SHORTS_END_ACQUIRE_Msk);
spis_interrupt_enable(SPIS_INTENSET_ACQUIRED_Msk);
spis_interrupt_enable(SPIS_INTENSET_END_Msk);
NVIC_SetPriority(SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn, 6);
NVIC_ClearPendingIRQ(SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn);
NVIC_EnableIRQ(SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn);
NRF_SPIS1->ENABLE = (SPIS_ENABLE_ENABLE_Enabled << SPIS_ENABLE_ENABLE_Pos);
some static functions
static volatile uint8_t tx_buffer[32] = "Hello.";
static volatile uint8_t rx_buffer[32];
static void spis_pins_init(void)
gpio_config_input(MOSI_PIN, GPIO_PIN_CNF_PULL_Disabled);
gpio_config_input(MISO_PIN, GPIO_PIN_CNF_PULL_Disabled);
gpio_config_input(CLK_PIN, GPIO_PIN_CNF_PULL_Disabled);
gpio_config_input(CS_PIN, GPIO_PIN_CNF_PULL_Disabled);
NRF_SPIS1->PSEL.MOSI = MOSI_PIN;
NRF_SPIS1->PSEL.MISO = MISO_PIN;
NRF_SPIS1->PSEL.SCK = CLK_PIN;
NRF_SPIS1->PSEL.CSN = CS_PIN;
static void spis_set_rx_buffer(uint8_t * buff, size_t length)
NRF_SPIS1->RXD.PTR = (uint32_t)buff;
NRF_SPIS1->RXD.MAXCNT = length;
static void spis_set_tx_buffer(uint8_t * buff, size_t length)
NRF_SPIS1->TXD.PTR = (uint32_t)buff;
NRF_SPIS1->TXD.MAXCNT = length;
static void spis_configure(void)
uint32_t config = SPIS_CONFIG_ORDER_MsbFirst;
config |= (SPIS_CONFIG_CPOL_ActiveHigh << SPIS_CONFIG_CPOL_Pos) |
(SPIS_CONFIG_CPHA_Leading << SPIS_CONFIG_CPHA_Pos);
NRF_SPIS1->CONFIG = config;
// default 0xFF
static void spis_def_set(uint8_t ch)
NRF_SPIS1->DEF = ch;
// default 0xFF
static void spis_orc_set(uint8_t orc)
NRF_SPIS1->ORC = orc;
static void spis_shorts_enable(uint32_t mask)
NRF_SPIS1->SHORTS |= mask;
static void spis_enable(void)
NRF_SPIS1->ENABLE = (SPIS_ENABLE_ENABLE_Disabled << SPIS_ENABLE_ENABLE_Pos);
static void spis_interrupt_enable(uint32_t mask)
NRF_SPIS1->INTENSET = mask;
This piece of code works fine without interrupt. But now I'm trying to enable interrupts to setup pointers for TX and RX buffers.
