Interfacing ble_app_uart with SPIS
I have two nrf52 where i send a msg to one nrf52 through ble_app_uart that has SPI Master(This is working).
I am trying to configure one more nrf  with ble_app_uart with SPIS .
I am not able to receive any data in the customised program that has both Ble_app_uart and SPIS.
But I am able to receive the data in peripheral/SPIS program.
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <inttypes.h>
#include <stdbool.h>
#include "nrf_delay.h"
#include "boards.h"
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_gpio.h"
#define PIN_GPIO  (18UL)
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//spi packages
#include "nrf_drv_spis.h"
#include "app_error.h"
#define SPIS_INSTANCE 1 /**< SPIS instance index. */
static const nrf_drv_spis_t spis = NRF_DRV_SPIS_INSTANCE(SPIS_INSTANCE);/**< SPIS instance. */
#define TEST_STRING "sos"
static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
static volatile bool spis_xfer_done; /**< Flag used to indicate that SPIS instance completed the transfer. */
//spi
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
//check 1
#define DEVICE_NAME                     "sample"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                0                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
APP_TIMER_DEF(conn_timer_id);  //Defines timer for connection
APP_TIMER_DEF(rst_timer_id);  //Defines timer for resets
bool conn_status = false;
bool state;
int a=1,b=0;
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
//spi functions
 * @brief SPIS user event handler.
 * @param event
void spis_event_handler(nrf_drv_spis_event_t event)
        nrf_gpio_cfg_output(16);
    if (event.evt_type == NRF_DRV_SPIS_XFER_DONE)
        spis_xfer_done = true;
 NRF_LOG_INFO("hello length  %d",m_length);
        NRF_LOG_INFO(" Transfer completed. Received: %s",(uint32_t)m_rx_buf);
               if(m_length == 4)
                NRF_LOG_INFO(" got string");
                 nrf_gpio_pin_write(16,1);
                 nrf_delay_ms(1000);
                 nrf_gpio_pin_write(16,0);
                 nrf_delay_ms(1000);
                 nrf_delay_ms(1000);
                 nrf_delay_ms(1000);
                 nrf_delay_ms(1000);
                 nrf_delay_ms(1000);
void spiInit()
    // Enable the constant latency sub power mode to minimize the time it takes
    // for the SPIS peripheral to become active after the CSN line is asserted
    // (when the CPU is in sleep mode).
    NRF_POWER->TASKS_CONSTLAT = 1;
//    bsp_board_init(BSP_INIT_LEDS);
//        nrf_gpio_cfg_output(16);
//    APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
//    NRF_LOG_DEFAULT_BACKENDS_INIT();
    NRF_LOG_INFO("SPIS example");
    nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
    spis_config.csn_pin               = APP_SPIS_CS_PIN;
    spis_config.miso_pin              = APP_SPIS_MISO_PIN;
    spis_config.mosi_pin              = APP_SPIS_MOSI_PIN;
    spis_config.sck_pin               = APP_SPIS_SCK_PIN;
    //APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
//    while (1)
//        memset(m_rx_buf, 0, m_length);
//        spis_xfer_done = false;
//        APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_length, m_rx_buf, m_length));
//        while (!spis_xfer_done)
//            __WFE();
//        NRF_LOG_FLUSH();
                //bsp_board_led_invert(BSP_BOARD_LED_4);
//spi
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
NRF_GPIO->PIN_CNF[PIN_GPIO] = (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos) |
                                (GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos) |
                                (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) |
                                (GPIO_PIN_CNF_PULL_Disabled << GPIO_PIN_CNF_PULL_Pos) |
                                (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos);
    nrf_gpio_cfg_output(16);//green
        nrf_gpio_cfg_output(14);//yellow
        nrf_gpio_cfg_output(15);//red
    nrf_gpio_pin_write(15,0);
           nrf_gpio_pin_write(14,0);
        uint32_t err_code;
        char data[p_evt->params.rx_data.length];
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++){
          if(p_evt->params.rx_data.p_data[i] < 128)
            data[i] = (char)p_evt->params.rx_data.p_data[i];
 //       printf("%s\n",data);
        data[(int)p_evt->params.rx_data.length] = '\0';
    if(strcmp(data,"true") == 0)
        printf("data is true");
          //app_uart_put("1");
        //  nrf_gpio_pin_toggle(16);
                            uint32_t volatile tmo;
                        tmo = 10000000;
    while (tmo--);
    NRF_GPIO->OUTSET = (1UL << PIN_GPIO);
//    NRF_GPIO->OUTSET = (1UL << PIN_GPIO1);
   tmo = 10000000;
    while (tmo--);
   NRF_GPIO->OUTCLR = (1UL << PIN_GPIO);
                   nrf_delay_ms(1000);
          printf("%d\n",a);
//   NRF_GPIO->OUTCLR = (1UL << PIN_GPIO1);
//nrf_gpio_pin_toggle(16);
//            nrf_delay_ms(500);
        else  if(strcmp(data,"express") == 0){
          app_uart_put("1");
        nrf_gpio_pin_write(14,1);
                        tmo = 10000000;
    while (tmo--);
   tmo = 10000000;
    while (tmo--);
                      tmo = 10000000;
    while (tmo--);
   tmo = 10000000;
    while (tmo--);
                   nrf_delay_ms(1000);
          printf("%d\n",a);
        else if(strcmp(data,"false") == 0)
        //printf(data);
         nrf_gpio_pin_write(15,1);
                   nrf_delay_ms(1000);
         printf("%d\n",b);
                 // app_uart_put("0");
//beep 1
                           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
//beep 2
           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
   //beep 3
           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
      //beep 4
           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
      //beep 5
           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
      //beep 6
           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
      //beep 7
           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
   //beep 8
           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
//beep 9
           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
   //beep 10
           tmo = 1000000;
    while (tmo--);
    tmo = 1000000;
    while (tmo--);
//  tmo = 1000;
//    while (tmo--);
//   tmo = 1000;
//    while (tmo--);
   //  nrf_gpio_pin_toggle(15);
//nrf_gpio_pin_write(15,1);
        //Send Ticket id
        else{
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            conn_status = true;
  //          printf("\nAPP Connected\n");
            NRF_LOG_INFO("Disconnected");
            state = true;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
	    switch (p_event->evt_type)
	        case APP_UART_DATA_READY:
	            index++;
	            if ((data_array[index - 1] == '\n') ||
	                (data_array[index - 1] == '\r') ||
	                (index >= m_ble_nus_max_data_len))
	                if (index > 1)
	                    do
	                    } while (err_code == NRF_ERROR_RESOURCES);
	                index = 0;
	            //APP_ERROR_HANDLER(p_event->data.error_communication);
	        case APP_UART_FIFO_ERROR:
/**@snippet [Sending Data to connected device]*/
static void uart_MAC_handle(){
  static uint8_t data_array[20];
  ret_code_t err;
  uint32_t err_code;
  uint16_t length;
  ble_gap_addr_t addr;
  uint8_t hex;
  bool one_check = false;
  err_code = sd_ble_gap_addr_get(&addr);
  //check 2
 data_array[0] = 'A';
  data_array[1] = '#';
  int j = 2;
  for(int i = 5; i >= 0; i--){
      uint8_t temp = addr.addr[i];
      int iter = 0;
        while (1) {
        hex = temp % 16;
        if(iter == 0){
          if(hex < 10) data_array[j+1] = hex + 48;
          else data_array[j+1] = hex + 55;
        else if(iter == 1){
          if(hex < 10) data_array[j] = hex + 48;
          else data_array[j] = hex + 55;
        iter++;
        if (temp>0) {
          temp /= 16;
        } else {
      j += 2;
      data_array[j] = 58;
      j++;
  data_array[j-1] = '#';
    printf(" the data that we are sending is data: %s \n", data_array);
  length = sizeof(data_array)/sizeof(char);
  while(1)
    if(conn_status){
      err = app_timer_start(conn_timer_id, APP_TIMER_TICKS(60000), NULL);
      APP_ERROR_CHECK(err);
      err = app_timer_stop(rst_timer_id);
//    if(state){
//    }else if (!state)
    if(data_array!= NULL && data_array!= "" && length >0 )
    ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
    nrf_delay_ms(300);
    printf("Not able to send the data");
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    int8_t tx_power_level = -20;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance = true;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.p_tx_power_level = &tx_power_level;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
/**@brief Function to set the tx power
*@param Possible values -40, -20, -16, -12, -8, -4, 0, 3, 4.
//check 3
static void tx_power_set(){
  ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, -12);
/**@snippet [Controlling the Range]*/
/**@brief Function for handling the connection timeout.
 * @param[out] BLE disconnects by the time execution finishes.
static void disconnect_handle(void * p_context){
  uint32_t err_code;
  ret_code_t err = err_code = app_timer_start(rst_timer_id, APP_TIMER_TICKS(600000), NULL);
  err_code = sd_nvic_SystemReset();
/**@brief Function for handling the reset timeout.
 * @param[out] BLE module gets a reset by the time execution finishes.
static void reset_handle(void * p_context){
  uint32_t err_code;
/**@brief Function for initializing and setting up the timer.
 * Initializes the timer library.
 * Creates the Reset and Connection timers.
static void set_timers(){
    uint32_t err_code = app_timer_init();
    err_code = app_timer_create(&conn_timer_id, APP_TIMER_MODE_REPEATED, disconnect_handle);
    err_code = app_timer_create(&rst_timer_id, APP_TIMER_MODE_REPEATED, reset_handle);
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
/**@brief Application main function.
//#define PIN_GPIO  (22UL)
    bool erase_bonds;
    // Initialize.
//    buzz();
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    set_timers();
    // Start execution.
   // printf("\r\nUART started.\r\n");
    //        app_uart_put("Start");
    advertising_start();
    tx_power_set();
    //spiInit();
    for(;;)
   // spiInit();
            __WFE();
        uart_MAC_handle();
    Just to confirm that I have understood your issue correctly: You have successfully achieved both BLE and UART communication between the devices, along with communication successful communication using SPI - but when you are merging the SPIS example with ble_app_uart you are unable to receive data?
    If so, could you tell me, is it the SPIS peripheral or the BLE_app_uart part that is unable to receive the data?
    Could you elaborate on what behavior you are seeing when you attempt to do this?
    I immediately notice that you never initialize your SPIS in the code you provided(spiInit is commented out of main, and nrf_drv_spis_init is commented out of spiInit..) - could you make sure that the code you have supplied is the correct version for which you have noticed this behavior?
    Karl
