Hi
I would like to ask you for advice on how to solve my problem with Ble and the timer I am trying to add a timer to examples\ble_peripheral\ble_app_uart the timer works properly unless it starts advertising_start (); and then the timer conflict with Ble begins. Does anyone have a solution to this problem ? I'm adding part of the timer code and timer settings in sdk_config and I'm also adding photos where to see my problem.
sdk_config.h
// <e> TIMER_ENABLED - nrf_drv_timer - TIMER periperal driver - legacy layer //========================================================== #ifndef TIMER_ENABLED #define TIMER_ENABLED 1 #endif // <o> TIMER_DEFAULT_CONFIG_FREQUENCY - Timer frequency if in Timer mode // <0=> 16 MHz // <1=> 8 MHz // <2=> 4 MHz // <3=> 2 MHz // <4=> 1 MHz // <5=> 500 kHz // <6=> 250 kHz // <7=> 125 kHz // <8=> 62.5 kHz // <9=> 31.25 kHz #ifndef TIMER_DEFAULT_CONFIG_FREQUENCY #define TIMER_DEFAULT_CONFIG_FREQUENCY 0 #endif // <o> TIMER_DEFAULT_CONFIG_MODE - Timer mode or operation // <0=> Timer // <1=> Counter #ifndef TIMER_DEFAULT_CONFIG_MODE #define TIMER_DEFAULT_CONFIG_MODE 0 #endif // <o> TIMER_DEFAULT_CONFIG_BIT_WIDTH - Timer counter bit width // <0=> 16 bit // <1=> 8 bit // <2=> 24 bit // <3=> 32 bit #ifndef TIMER_DEFAULT_CONFIG_BIT_WIDTH #define TIMER_DEFAULT_CONFIG_BIT_WIDTH 0 #endif // <o> TIMER_DEFAULT_CONFIG_IRQ_PRIORITY - Interrupt priority // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 // <4=> 4 // <5=> 5 // <6=> 6 // <7=> 7 #ifndef TIMER_DEFAULT_CONFIG_IRQ_PRIORITY #define TIMER_DEFAULT_CONFIG_IRQ_PRIORITY 6 #endif // <q> TIMER0_ENABLED - Enable TIMER0 instance #ifndef TIMER0_ENABLED #define TIMER0_ENABLED 0 #endif // <q> TIMER1_ENABLED - Enable TIMER1 instance #ifndef TIMER1_ENABLED #define TIMER1_ENABLED 0 #endif // <q> TIMER2_ENABLED - Enable TIMER2 instance #ifndef TIMER2_ENABLED #define TIMER2_ENABLED 1 #endif // <q> TIMER3_ENABLED - Enable TIMER3 instance #ifndef TIMER3_ENABLED #define TIMER3_ENABLED 0 #endif // <q> TIMER4_ENABLED - Enable TIMER4 instance #ifndef TIMER4_ENABLED #define TIMER4_ENABLED 0 #endif // </e>
setup timer and GPIO
#define GPIO_24 NRF_GPIO_PIN_MAP(0,24)
const nrf_drv_timer_t TIMER_2 = NRF_DRV_TIMER_INSTANCE(2);
void timer_init(void)
NRF_TIMER2->TASKS_STOP = 1;
NRF_TIMER2->SHORTS = (TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos);
NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;
NRF_TIMER2->BITMODE = (TIMER_BITMODE_BITMODE_24Bit << TIMER_BITMODE_BITMODE_Pos);
NRF_TIMER2->PRESCALER = 1;
NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE0_Set << TIMER_INTENSET_COMPARE0_Pos);
NRF_TIMER2->CC[0] = 100;
NRF_TIMER2->TASKS_START = 1;
NVIC_EnableIRQ(TIMER2_IRQn);
void TIMER2_IRQHandler(void)
if (NRF_TIMER2->EVENTS_COMPARE[0])
nrf_gpio_pin_toggle(GPIO_24);
NRF_TIMER2->EVENTS_COMPARE[0] = 0;
not start advertising_start ();
