how can we use different 128 Bit UUID for different read/write in pc-ble-driver-py?
Hi ,
for example i defined three different characteristic 128 bit UUID for different operations
TEST_CHAR_ONE = BLEUUIDBase([0x12, 0x23, 0x00, 0x00, 0x56, 0x78, 0x99, 0xaa, 0xbb, 0xcc, 0xdd, 0xee, 0xff, 0x54, 0x49, 0x43])
TEST_CHAR_ONE_UUID = BLEUUID(0x1456, TEST_CHAR_ONE)
TEST_CHAR_TWO = BLEUUIDBase([0xaa, 0xbb, 0x00, 0x00, 0xcc, 0xdd, 0xee, 0xaa, 0xbb, 0xcc, 0xdd, 0xee, 0xff, 0x66, 0x98, 0x76])
TEST_CHAR_TWO_UUID = BLEUUID(0x1456, TEST_CHAR_TWO)
TEST_CHAR_THREE = BLEUUIDBase([0x99, 0x88, 0x00, 0x00, 0x11, 0x22, 0x87, 0x65, 0x43, 0x21, 0xdd, 0xee, 0xff, 0x76, 0x87, 0x87])
TEST_CHAR_THREE_UUID = BLEUUID(0x1456, TEST_CHAR_THREE)
self.adapter.driver.ble_vs_uuid_add(TEST_CHAR_ONE_UUID)
self.adapter.driver.ble_vs_uuid_add(TEST_CHAR_TWO_UUID)
self.adapter.driver.ble_vs_uuid_add(TEST_CHAR_THREE_UUID)
self.adapter.enable_notification(TEST_CHAR_ONE_UUID)
self.adapter.enable_notification(TEST_CHAR_TWO_UUID)
self.adapter.enable_notification(TEST_CHAR_THREE_UUID)
i got error CCCD not found
"pc_ble_driver_py.exceptions.NordicSemiException: CCCD not found"
please support how to read and write operations on for different 128 bit UUID .
    Do all three characteristics have a CCCD descriptor and have you completed service discovery when you try to enable notifications? I'm including another example here which demonstrates how you can enable notifications for a custom characteristic:
    # Copyright (c) 2016 Nordic Semiconductor ASA
    # All rights reserved.
    # Redistribution and use in source and binary forms, with or without modification,
    # are permitted provided that the following conditions are met:
    #   1. Redistributions of source code must retain the above copyright notice, this
    #   list of conditions and the following disclaimer.
    #   2. Redistributions in binary form must reproduce the above copyright notice, this
    #   list of conditions and the following disclaimer in the documentation and/or
    #   other materials provided with the distribution.
    #   3. Neither the name of Nordic Semiconductor ASA nor the names of other
    #   contributors to this software may be used to endorse or promote products
    #   derived from this software without specific prior written permission.
    #   4. This software must only be used in or with a processor manufactured by Nordic
    #   Semiconductor ASA, or in or with a processor manufactured by a third party that
    #   is used in combination with a processor manufactured by Nordic Semiconductor.
    #   5. Any software provided in binary or object form under this license must not be
    #   reverse engineered, decompiled, modified and/or disassembled.
    # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
    # ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
    # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
    # DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
    # ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
    # (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
    # LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
    # ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    # (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
    # SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    import sys
    import time
    import logging
    from queue import Queue, Empty
    from pc_ble_driver_py.observers import *
    TARGET_DEV_NAME = "Nordic_UART"
    CONNECTIONS = 1
    CFG_TAG = 1
    def init(conn_ic_id):
        # noinspection PyGlobalUndefined
        global config, BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID, BLEUUIDBase, BLEConfigCommon, BLEConfig, BLEConfigConnGatt, BLEGapScanParams
        from pc_ble_driver_py import config
        config.__conn_ic_id__ = conn_ic_id
        # noinspection PyUnresolvedReferences
        from pc_ble_driver_py.ble_driver import (
            BLEDriver,
            BLEAdvData,
            BLEEvtID,
            BLEEnableParams,
            BLEGapTimeoutSrc,
            BLEUUID,
            BLEUUIDBase,
            BLEGapScanParams,
            BLEConfigCommon,
            BLEConfig,
            BLEConfigConnGatt,
        from pc_ble_driver_py.ble_adapter import BLEAdapter
        global nrf_sd_ble_api_ver
        nrf_sd_ble_api_ver = config.sd_api_ver_get()
    class NusCollector(BLEDriverObserver, BLEAdapterObserver):
        def __init__(self, adapter):
            super(NusCollector, self).__init__()
            self.first = 1
            self.adapter = adapter
            self.conn_q = Queue()
            self.adapter.observer_register(self)
            self.adapter.driver.observer_register(self)
            self.adapter.default_mtu = 247
            self.nus_base = BLEUUIDBase([
                0x6e, 0x40, 0x00, 0x00, 0xb5, 0xa3, 0xf3, 0x93, 0xe0, 0xa9, 0xe5, 0x0e, 0x24, 0xdc, 0xca, 0x9e
            self.nus_rx = BLEUUID(0x0002, self.nus_base)
            self.nus_tx = BLEUUID(0x0003, self.nus_base)
        def open(self):
            self.adapter.driver.open()
            if config.__conn_ic_id__ == "NRF51":
                self.adapter.driver.ble_enable(
                    BLEEnableParams(
                        vs_uuid_count=1,
                        service_changed=0,
                        periph_conn_count=0,
                        central_conn_count=1,
                        central_sec_count=0,
            elif config.__conn_ic_id__ == "NRF52":
                gatt_cfg = BLEConfigConnGatt()
                gatt_cfg.att_mtu = self.adapter.default_mtu
                gatt_cfg.tag = CFG_TAG
                self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
                self.adapter.driver.ble_enable()
                self.adapter.driver.ble_vs_uuid_add(self.nus_base)
        def close(self):
            self.adapter.driver.close()
        def connect_and_discover(self):
            scan_duration = 5
            params = BLEGapScanParams(interval_ms=200, window_ms=150, timeout_s=scan_duration)
            message = "We are connected!\r\n"
            self.adapter.driver.ble_gap_scan_start(scan_params=params)
            try:
                new_conn = self.conn_q.get(timeout=scan_duration)
                self.adapter.service_discovery(new_conn)
                self.adapter.enable_notification(new_conn, self.nus_tx)
                data = [ord(n) for n in list(message)]
                self.adapter.write_cmd(new_conn, self.nus_rx, data)
                return new_conn
            except Empty:
                print("No device advertising with name {TARGET_DEV_NAME} found.")
                return None
        def on_gattc_evt_exchange_mtu_rsp(self, ble_driver, conn_handle, status, att_mtu):
            print("ATT MTU updated to {}".format(att_mtu))
        def on_gap_evt_data_length_update(
            self, ble_driver, conn_handle, data_length_params
            print("Max rx octets: {}".format(data_length_params.max_rx_octets))
            print("Max tx octets: {}".format(data_length_params.max_tx_octets))
            print("Max rx time: {}".format(data_length_params.max_rx_time_us))
            print("Max tx time: {}".format(data_length_params.max_tx_time_us))
        def on_gatts_evt_exchange_mtu_request(self, ble_driver, conn_handle, client_mtu):
            print("Client requesting to update ATT MTU to {} bytes".format(client_mtu))
        def on_gap_evt_connected(
            self, ble_driver, conn_handle, peer_addr, role, conn_params
            print("New connection: {}".format(conn_handle))
            self.conn_q.put(conn_handle)
        def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
            print("Disconnected: {} {}".format(conn_handle, reason))
        def on_gap_evt_adv_report(
            self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
            elif BLEAdvData.Types.short_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
            else:
                return
            dev_name = "".join(chr(e) for e in dev_name_list)
            address_string = "".join("{0:02X}".format(b) for b in peer_addr.addr)
            print(
                "Received advertisment report, address: 0x{}, device_name: {}".format(
                    address_string, dev_name
            if dev_name == TARGET_DEV_NAME:
                self.adapter.connect(peer_addr, tag=CFG_TAG)
        def on_notification(self, ble_adapter, conn_handle, uuid, data):
            if len(data) > 32:
                data = "({}...)".format(data[0:10])
            print("Connection: {}, {} = {}".format(conn_handle, uuid, data))
    def main(selected_serial_port):
        print("Serial port used: {}".format(selected_serial_port))
        driver = BLEDriver(
            serial_port=selected_serial_port, auto_flash=False, baud_rate=1000000, log_severity_level="info"
        adapter = BLEAdapter(driver)
        collector = NusCollector(adapter)
        collector.open()
        conn = collector.connect_and_discover()
        while conn is not None:
            time.sleep(100)
        collector.close()
    def item_choose(item_list):
        for i, it in enumerate(item_list):
            print("\t{} : {}".format(i, it))
        print(" ")
        while True:
            try:
                choice = int(input("Enter your choice: "))
                if (choice >= 0) and (choice < len(item_list)):
                    break
            except Exception:
                pass
            print("\tTry again...")
        return choice
    if __name__ == "__main__":
        logging.basicConfig(
            level="DEBUG",
            format="%(asctime)s [%(thread)d/%(threadName)s] %(message)s",
        serial_port = None
        if len(sys.argv) < 2:
            print("Please specify connectivity IC identifier (NRF51, NRF52)")
            exit(1)
        init(sys.argv[1])
        if len(sys.argv) == 3:
            serial_port = sys.argv[2]
        else:
            descs = BLEDriver.enum_serial_ports()
            choices = ["{}: {}".format(d.port, d.serial_number) for d in descs]
            choice = item_choose(choices)
            serial_port = descs[choice].port
        main(serial_port)
        quit()
