I´m using the NRF52810 device and have an issue with the SAADC peripheral.
I basically have 2 channel where i want to do some averaging to improve noise.
The setup is as follows:
// Configure SAADC singled-ended channel, Internal reference (0.6V) and 1/2 gain. This gives input range 0-1.2V
NRF_SAADC->CH[0].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_2 << SAADC_CH_CONFIG_GAIN_Pos) |
(SAADC_CH_CONFIG_MODE_SE << SAADC_CH_CONFIG_MODE_Pos) |
(SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
(SAADC_CH_CONFIG_RESN_Bypass << SAADC_CH_CONFIG_RESN_Pos) |
(SAADC_CH_CONFIG_RESP_Bypass << SAADC_CH_CONFIG_RESP_Pos) |
(SAADC_CH_CONFIG_TACQ_3us << SAADC_CH_CONFIG_TACQ_Pos) |
(SAADC_CH_CONFIG_BURST_Enabled << SAADC_CH_CONFIG_BURST_Pos);
// Configure the SAADC channel with VDD as positive input, no negative input(single ended).
NRF_SAADC->CH[0].PSELP = SAADC_CH_PSELP_PSELP_AnalogInput2 << SAADC_CH_PSELP_PSELP_Pos;
NRF_SAADC->CH[0].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
//Channel 6 - NTC
// Configure SAADC singled-ended channel, Reference (VDD/4) and 1/4 gain. This gives input range 0-VDD
NRF_SAADC->CH[1].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_4 << SAADC_CH_CONFIG_GAIN_Pos) |
(SAADC_CH_CONFIG_REFSEL_VDD1_4 << SAADC_CH_CONFIG_REFSEL_Pos) |
NRF_SAADC->CH[1].PSELP = SAADC_CH_PSELP_PSELP_AnalogInput6 << SAADC_CH_PSELP_PSELP_Pos;
NRF_SAADC->CH[1].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
// Configure the SAADC resolution.
NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_14bit << SAADC_RESOLUTION_VAL_Pos;
// Configure result to be put in RAM at the location of "result" variable.
// Average result will be sent to memory, 2 channels means 2 average values.
//NRF_SAADC->RESULT.MAXCNT = 2;
//NRF_SAADC->OVERSAMPLE = SAADC_OVERSAMPLE_OVERSAMPLE_Over16x << SAADC_OVERSAMPLE_OVERSAMPLE_Pos;
NRF_SAADC->OVERSAMPLE = SAADC_OVERSAMPLE_OVERSAMPLE_Over256x << SAADC_OVERSAMPLE_OVERSAMPLE_Pos;
//adcResult is of size 2
NRF_SAADC->RESULT.PTR = (uint32_t)&adcResult[0];
// No automatic sampling, will trigger with TASKS_SAMPLE.
NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
// Enable SAADC (would capture analog pins if they were used in CH[0].PSELP)
NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos;
// Calibrate the SAADC (only needs to be done once in a while)
NRF_SAADC->TASKS_CALIBRATEOFFSET = 1;
while (NRF_SAADC->EVENTS_CALIBRATEDONE == 0);
NRF_SAADC->EVENTS_CALIBRATEDONE = 0;
while (NRF_SAADC->STATUS == (SAADC_STATUS_STATUS_Busy <<SAADC_STATUS_STATUS_Pos));
When the adc is started (task started), i want to collect several samples in a loop.
void StartAdcWaitForResult()
// Do a SAADC sample, will put the result in the configured RAM buffer.
NRF_SAADC->TASKS_SAMPLE = 1;
while (NRF_SAADC->EVENTS_END == 0);
NRF_SAADC->EVENTS_END = 0;
while(sampleCounter-- > 0)
StartAdcWaitForResult();
raw_signals[0] = adcResult[0];
raw_signals[1] = adcResult[0];
SendData();
It works the first time, then the StartAdcWaitForResult hangs (since the end event never happens again).
If i trigger the TASK_STOP and then TASK_START before StartAdcWaitForResult it works, not sure why.
But I assume this is not how it´s suppose to be working...?
