Single SPI transfer from PPI
I want to set up a SPI transfer so the transfer itself is triggered by PPI. The PPI is set up working, the chain of events is
  1. Timer CC0 -> Set CS low
  2. Timer CC1 -> Start SPI
  3. SPI end -> Set CS high
Now, I want to send a packet of 2 bytes for transmission on the next timer event (note this is TX only, no RX)
My SPI descriptor is
static uint8_t dac_buf[2];
nrfx_spim_xfer_desc_t const xfer_desc = NRFX_SPIM_SINGLE_XFER(dac_buf, 2, NULL, 0);
and I send the packet by
nrfx_spim_xfer(&spi_inst, &xfer_desc,NRFX_SPIM_FLAG_HOLD_XFER);
but I'm getting the same 2 bytes sent every timer event. Can I expect the single xfer to work like this, or do I need to be enabling/disabling the PPI channels to start/stop transmission?
Parents Reply
  • Hi
    You're right, I was getting an error. I was setting the PPI channel by NRF_PPI->CHENSET |= (1 << ppi_cs_low) but using the driver to disable it (it was a quick test and late in the day!) which was returning unallocated channel errors.
    The good news is it works by enabling / disabling PPI so I can happily play 44.1kHz audio from a WAV file which is pretty impressive Slight smile The bad news is it won't work with BLE but that's probably because my PPI is upsetting the Softdevice - tomorrow's job is to rewrite the PPI stuff properly using the drivers.
    Thanks
    Nick
