Debugger Options
  I've got an nRF52840 dev kit and am building my code using the app_ble_hrs_freertos project as a starting point.  I'm building the .elf file, which I load into Ozone to do debugging.  I'm able to flash the program using Ozone.  I can single-step through the 1st couple of function calls, but when I get to ble_stack_init, I get a hard fault.  If I disconnect Ozone and let the code that I downloaded just run, it runs fine.  It outputs messages to the debug UART, and I can see the board advertising from my phone.  I have tried running within Ozone from the start of main without single-stepping and with no breakpoints set, but I always hit the hard fault.
  - What do I need to do to get Ozone debugging to work?
  - If Ozone doesn't work for whatever reason, is there another debug solution that is recommended?
  Thanks!
Brian
