Update NFC content on-the-fly
I want update NFC payload on-the-fly.
My test firmware based on nRF5_SDK_14.2.0_17b948a\examples\nfc\record_text (unable to update SDK. Legacy part.)
At firmware start:
/* Set up NFC */
err_code = nfc_t2t_setup(nfc_callback, NULL);
/* Encode welcome message */
err_code = welcome_msg_encode(m_ndef_msg_buf, &len);
/* Set created message as the NFC payload */
err_code = nfc_t2t_payload_set(m_ndef_msg_buf, len);
/* Start sensing NFC field */
err_code = nfc_t2t_emulation_start();
I am try update NFC payload:
err_code = msg_encode(m_ndef_msg_buf, &len);
nfc_t2t_payload_set is return NRF_ERROR_INVALID_STATE
Ok. I will call nfc_t2t_emulation_stop before update payload
nfc_t2t_emulation_stop();
That's working.
BUT I have next issue:
When I call nfc_t2t_emulation_stop, nfc_t2t_payload_set and nfc_t2t_emulation_start while tag at field(after NFC_T2T_EVENT_FIELD_ON) something went wrong and NFC tag unavailable for reader forever.
    Did you check the return code from call to nfc_t2t_emulation_stop? It may be that you cannot call these functions from interrupt context. Can you try to set a flag in the event handler, and do the payload update in the main context?
    Jørgen
  • I have call nfc_t2t_emulation_stop from application context.
    main.c
    nfc_init("1", "2");
    nrf_delay_ms(5000);
    nfc_start("3");
    nfc.c
    static void nfc_callback(void * p_context, nfc_t2t_event_t event, const uint8_t * p_data, size_t data_length)
        (void)p_context;
        switch (event)
            case NFC_T2T_EVENT_FIELD_ON:
                NRF_LOG_DEBUG("NFC_T2T_EVENT_FIELD_ON");
            case NFC_T2T_EVENT_FIELD_OFF:
                NRF_LOG_DEBUG("NFC_T2T_EVENT_FIELD_OFF");
            case NFC_T2T_EVENT_DATA_READ:
    			NRF_LOG_DEBUG("NFC_T2T_EVENT_DATA_READ");
            case NFC_T2T_EVENT_STOPPED:
    			NRF_LOG_DEBUG("NFC_T2T_EVENT_STOPPED");
    void nfc_init(char *p_fw_ver, char *p_hw_rev)
    	NRF_LOG_DEBUG("NFC init");
    	uint32_t  err_code;
    	uint32_t  len = sizeof(m_ndef_msg_buf);
    void nfc_start(char *test)
    	NRF_LOG_DEBUG("NFC start");
    	uint32_t  err_code;
    	err_code = nfc_t2t_emulation_stop();
    	NRF_LOG_DEBUG("nfc_t2t_emulation_stop: 0x%x", err_code);
    logs with issue:
    00> [00000000] <debug> NFC: NFC init
    00> [00001374] <debug> NFC: NFC_T2T_EVENT_FIELD_ON
    00> [00001491] <debug> NFC: NFC_T2T_EVENT_DATA_READ
    00> [00005110] <debug> NFC: NFC start
    00> [00005110] <debug> NFC: nfc_t2t_emulation_stop: 0x0
    logs without issue:
    00> [00003898] <debug> NFC: NFC_T2T_EVENT_FIELD_ON
    00> [00004017] <debug> NFC: NFC_T2T_EVENT_DATA_READ
    00> [00004402] <debug> NFC: NFC_T2T_EVENT_FIELD_OFF
    00> [00005014] <debug> NFC: NFC start
    00> [00005014] <debug> NFC: nfc_t2t_emulation_stop: 0x0
    00> [00009423] <debug> NFC: NFC_T2T_EVENT_FIELD_ON
    00> [00009541] <debug> NFC: NFC_T2T_EVENT_DATA_READ
    00> [00009806] <debug> NFC: NFC_T2T_EVENT_FIELD_OFF
    Issue: Unable to update NFC payload after NFC_T2T_EVENT_FIELD_ON event. Tag is unavailable for any readers.
  • I made a modified version of the NFC record_url example, but I'm not able to reproduce the issue you are seeing:
    <info> app: NFC URL start
    <info> app: nfc_t2t_emulation_stop
    <info> app: nfc_t2t_emulation_start
    <info> app: NFC_T2T_EVENT_FIELD_ON
    <info> app: NFC_T2T_EVENT_DATA_READ
    <info> app: NFC_T2T_EVENT_FIELD_OFF
    Here is the project I used (SDK 14.2.0): record_url_update.zip
    Can you share the project you used to reproduce this?
  • Thanks a lot for you help!
    You example works fine for my case. I will try find issue at my code.
  • I have found a issue.
    Details at nRF5_SDK_14.2.0\components\nfc\t2t_lib\nfc_fixes.h.
    I do not have BOARD_PCA10040 define for my custom board.
    HAL_NFC_ENGINEERING_BC_FTPAN_WORKAROUND define fix my issue.
