NRF flash storage event handler issue with Bluetooth advertising.
Hi Team,
We are facing issue with Flash storage Handlers with ble handlers. When we add the fstorage to my application ble adversing is stopped suddenly.
We are having separate Event handlers for both. We have some concerns related to fstorage,
1. How to set the start and end addresses of an fstorage instance at runtime, at the end of current application usage.
fstorage example code we have found we below code snippet , but to use this macro and nowhere it is called in application
                                    NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
                                       /* Set a handler for fstorage events. */
.                                           evt_handler = fstorage_evt_handler,
                                         /* These below are the boundaries of the flash space assigned to this instance of fstorage.
                                           * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
                                                 * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
                                                     * last page of flash available to write data. */
                                                  .start_addr = 0x4e000,
                                                 .end_addr = 0x4f000,
2. Providing the fs Read/write functions code here for cross verification,
Fstorage Handler:
static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt)
if (p_evt->result != NRF_SUCCESS)
return;
switch (p_evt->id)
case NRF_FSTORAGE_EVT_WRITE_RESULT:
m_fs_Data_write = 1;
case NRF_FSTORAGE_EVT_ERASE_RESULT:
m_fs_Data_erase = 1;
case NRF_FSTORAGE_EVT_READ_RESULT:
m_fs_Data_read = 1;
Write Function:
void Update_flash_Data(void)
ret_code_t rc;
rc = nrf_fstorage_erase(&fstorage, (uint32_t)(KEY_BASE_ADDR), 1, NULL);
APP_ERROR_CHECK(rc);
if(m_fs_Data_erase == 1)
m_fs_Data_erase = 0;
rc = nrf_fstorage_write(&fstorage, (uint32_t)KEY_BASE_ADDR, &m_sffl_data, sizeof(m_sffl_data), NULL);
//wait_for_flash_ready(&fstorage);
Read Handler:
void Read_Flash_Data(void)
ret_code_t rc;
rc = nrf_fstorage_read(&fstorage, (uint32_t)KEY_BASE_ADDR, &m_sffl_data, sizeof(m_sffl_data));
Is there any modifications required in Event handler and Write/Read handlers.
Srinivas.V
  • Hi Haakonsh,
    Thanks for your reply.We are using the SD Flash Api's only inside the wrapper functions we are calling the same SD Api's only.
    Coming to Concurrent multi protocol implementation is there any example code for reference, we will use the same concept for our design.
    Srinivas.V
  • Hi Haakonsh,
    Thanks for your reply.We have some more questions on FLASH API timing and other things.
    1. How to enable flash timing-event scheduling in any available time left between other timing-events.
    2. How to configure the code to run the Flash API in a low priority,in which file we need to do this activity.
    3. How to configure and use the Time slot Flash API's apart from Normal Flash API ,like "sd_flash_write" and "sd_flash_erase".
    4. Is there any way to know the Blue tooth is in  ideal state, in that slot we can execute this Flash API's.
    Flash is running at Fourth priority and we can't change this , my intention is how to implement or use  the above mentioned points in our Application,  is there any specific example for Flash timing api's and other things.I haven't found any specific api's for flash apart from i mentioned above.
    Fourth priority
    • Flash access
    • Radio Timeslot with normal priority
    Srinivas.V
    1. The scheduling of flash access is handled by the SoftDevice.
    2. It has a fixed low priority.
    3. See sd_radio_request, sd_radio_session_open, and sd_radio_session_close. You can use the storage API when in a Timeslot. You have to specify the length of the timeslot in µs, and since the flash operations are deterministic you can divide your flash operations into parts that fit into a given Timeslot.
    4. Yes, see (3).
  • Hi Haakonsh,
    3. what was the API or Macro to configure the storage API time slot length in µs and flash data size is less than 256 bytes only.
    Here with i am sharing my flash design in my application,
    /Flash Data is updated ,writing to Flash sector based on runtime flag
    if((true == m_fs_Data_Update) && (true == m_ble_idle_flage))
            m_fs_Data_Update = false;
             m_ble_idle_flage = false;
    CRITICAL_REGION_ENTER();
                 Update_flash_Data();
    CRITICAL_REGION_EXIT();
    ret_code_t err_code;
    switch (ble_adv_evt)
    case BLE_ADV_EVT_FAST:
                 NRF_LOG_INFO("Fast advertising.");
    case BLE_ADV_EVT_IDLE:
        m_ble_idle_flage = true;    //when ever ble is idle we are writing the data to flash.
               sleep_mode_enter();
            ret_code_t rc;
             uint32_t len = round_up_u32(sizeof(m_sffl_data));
               rc = nrf_fstorage_erase(&fstorage, fstorage.start_addr, 1, NULL);
             rc = nrf_fstorage_write(&fstorage,fstorage.start_addr, &m_sffl_data, len, NULL);
    void fs_Init(void)
                ret_code_t rc;
                nrf_fstorage_api_t * p_fs_api;
           #ifdef SOFTDEVICE_PRESENT
          p_fs_api = &nrf_fstorage_sd;
           #else
                   p_fs_api = &nrf_fstorage_nvmc;
            rc = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
    /* It is possible to set the start and end addresses of an fstorage instance at runtime.
    * They can be set multiple times, should it be needed. The helper function below can
    * be used to determine the last address on the last page of flash memory available to
    * store data. */
             (void) nrf5_flash_end_addr_get();
    Is there any other design technique to implement the Flash operations without disturbing the BLE functionalities.
    Regards.
    Srinivas.V
     Yes, use the SoftDevice Flash API in a Timeslot as explained previously.
  • Hi Haakansh,
    Again and again we are asking same question, you are giving same reply, means we are not connecting with your answer and not getting clarity.
    Can you give me any sample code or code snippet which will explain more clearly about how to use the SD Time slot API's for flash. we are using the soft device flash API only.
    We are asking how to use the Time slot API's and these are different with current API's ,what we are using now.we have shared code as well , you not looked at the code at all. The way you are giving answers was not getting clarity.
    Srinivas.V
  • Hi Haakansh,
    Srinivas.V
