Mesh SDK v4.1.0: attempt to add a second app_key to LPN results in ACCESS_STATUS_INSUFFICIENT_RESOURCES
1. This is on the stock LPN example, with one change to debug-print `status_code` inside handle_appkey_add().
Here is the diff:
diff --git a/models/foundation/config/src/config_server.c b/models/foundation/config/src/config_server.c
index 3993942..6fa9daa 100644
--- a/models/foundation/config/src/config_server.c
+++ b/models/foundation/config/src/config_server.c
@@ -627,8 +627,6 @@ static void handle_appkey_add(access_model_handle_t handle, const access_message
     evt.type = CONFIG_SERVER_EVT_APPKEY_ADD;
     status = dsm_appkey_add(appkey_index, network_handle, p_pdu->appkey, &evt.params.appkey_add.appkey_handle);
-    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "dsm_appkey_add(appkey_handle:%X appkey_index:%X)\n", evt.params.appkey_add.appkey_handle, appkey_index );
     switch (status)
         case NRF_SUCCESS:
@@ -660,6 +658,10 @@ static void handle_appkey_add(access_model_handle_t handle, const access_message
+    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO,
+            "dsm_appkey_add(appkey_handle:%X appkey_index:%X) status code: %X\n",
+            evt.params.appkey_add.appkey_handle, appkey_index, status_code);
     send_appkey_status(handle, p_message, status_code, key_indexes);
     if (status == NRF_SUCCESS)
2. To reproduce:
- flash and provision
- attempt to add a second application key (via proxy)
- device returns ACCESS_STATUS_INSUFFICIENT_RESOURCES (aka 0x05)
- establish friendship
- attempt to add a second application key (via friendship)
This is the log output:
<t:          0>, main.c,  580, ----- BLE Mesh LPN Demo -----
<t:       9326>, main.c,  530, Initializing and adding models
<t:      14250>, mesh_app_utils.c,   66, Device UUID (raw): BC354729418A465A8BEE4596D3225B67
<t:      14254>, mesh_app_utils.c,   71, Device UUID : BC354729-418A-465A-8BEE-4596D3225B67
<t:      14270>, main.c,  644,
		 Button/RTT 1) Send the on message.
		 Button/RTT 2) Send the off message.
		 Button/RTT 3) Establish or terminate friendship.
		 Button/RTT 4) Clear all the states to reset the node.
<t:     880839>, ble_softdevice_support.c,  104, Successfully updated connection parameters
<t:    1344686>, main.c,  163, Successfully provisioned
<t:    1344693>, main.c,  158, Node Address: 0x00A0
<t:    1384147>, ble_softdevice_support.c,  104, Successfully updated connection parameters
<t:    1859228>, config_server.c,  663, dsm_appkey_add(appkey_handle:0 appkey_index:0) status code: 0
<t:    1874924>, config_server.c, 2540, Access  Info:
		element_index=0		model_id = 2-FFFF		model_handle=1
<t:    1890652>, config_server.c, 2540, Access  Info:
		element_index=1		model_id = 1001-FFFF		model_handle=2
<t:    2165918>, config_server.c,  663, dsm_appkey_add(appkey_handle:FFFF appkey_index:1) status code: 5
<t:    5886138>, main.c,  366, Button 3 pressed
<t:    5886141>, main.c,  293, Initiating the friendship establishment procedure.
<t:    5889537>, main.c,  451, Received friend offer from 0x000D
<t:    5892895>, main.c,  498, Friendship established with: 0x000D
<t:    6208382>, config_server.c,  663, dsm_appkey_add(appkey_handle:FFFF appkey_index:1) status code: 5
<t:    6213433>, main.c,  480, Friend poll procedure complete
3. Here are all details for the build:
-- Configuring CMake for nRF5 SDK for Bluetooth Mesh 4.1.0
-- SDK: nRF5_SDK_16.0.0_98a08e2
-- Platform: nrf52832_xxAA
-- Arch: cortex-m4f
-- SoftDevice: s132_7.0.1
-- Board: pca10040
-- The C compiler identification is GNU 8.3.1
