Somehow my account got deleted and so did my ticket.
I had to re-register my account an i'm creating this ticket again:
nrf9160_pca10090ns.dts.pre.tmp:89.42-101.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
nrf9160_pca10090ns.dts.pre.tmp:338.19-344.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
CMake Error at /Users/Mark/Documents/zephr/ncs/zephyr/cmake/extensions.cmake:1457 (message):
Assertion failed: The toolchain is unable to build a dummy C file. See
CMakeError.log.
/Users/Mark/Documents/zephr/ncs/zephyr/CMakeLists.txt:42 (assert)
Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
Compiler: /opt/gnuarmemb/bin/arm-none-eabi-gcc
Build flags:
Id flags:
The output was:
1
clang: error: unknown argument '-meabi=5'; did you mean '-mabi=5'?
Build flags:
Id flags: -c
The output was:
1
Build flags:
Id flags: -Aa
The output was:
1
<command-line>: error: missing '(' after predicate
Build flags:
Id flags: -D__CLASSIC_C__
The output was:
1
Build flags:
Id flags: --target=arm-arm-none-eabi;-mcpu=cortex-m3
The output was:
1
arm-none-eabi-gcc: error: unrecognized command line option '--target=arm-arm-none-eabi'
Build flags:
Id flags:
The output was:
1
Build flags:
Id flags: -c
The output was:
1
Build flags:
Id flags: -Aa
The output was:
1
Build flags:
The output was:
1
Build flags:
The output was:
1
Checking whether the C compiler is IAR using "" did not match "IAR .+ Compiler":
arm-none-eabi-gcc: fatal error: no input files
compilation terminated.
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Build flags:
Id flags:
The output was:
1
Build flags:
Id flags: -c
The output was:
1
Build flags:
Id flags: --c++
The output was:
1
arm-none-eabi-gcc: error: unrecognized command line option '--c++'
Build flags:
Id flags: --ec++
The output was:
1
arm-none-eabi-gcc: error: unrecognized command line option '--ec++'; did you mean '-Weffc++'?
Build flags:
The output was:
1
Build flags:
Id flags:
The output was:
1
Build flags:
Id flags: -c
The output was:
1
Build flags:
Id flags: --c++
The output was:
1
Build flags:
Id flags: --ec++
The output was:
1
Build flags:
The output was:
1
Checking whether the CXX compiler is IAR using "" did not match "IAR .+ Compiler":
Performing C SOURCE FILE Test check_C__nostartfiles__nostdlib__isystem___opt_gnuarmemb_bin____lib_gcc_arm_none_eabi_8_3_1_include___isystem___opt_gnuarmemb_bin____lib_gcc_arm_none_eabi_8_3_1_include_fixed___Wl___unresolved_symbols_ignore_in_object_files__Wl___entry_0 failed with the following output:
Change Dir: /Users/Mark/Documents/zephr/ncs/nrf/samples/nrf9160/at_client/build_nrf9160_pca10090ns/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/local/bin/ninja cmTC_6fed0 && [1/2] Building C object CMakeFiles/cmTC_6fed0.dir/src.c.obj
FAILED: CMakeFiles/cmTC_6fed0.dir/src.c.obj
/opt/gnuarmemb/bin/arm-none-eabi-gcc -Dcheck_C__nostartfiles__nostdlib__isystem___opt_gnuarmemb_bin____lib_gcc_arm_none_eabi_8_3_1_include___isystem___opt_gnuarmemb_bin____lib_gcc_arm_none_eabi_8_3_1_include_fixed___Wl___unresolved_symbols_ignore_in_object_files__Wl___entry_0 -nostartfiles -nostdlib -isystem "/opt/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include" -isystem "/opt/gnuarmemb/bin/../lib/gcc/arm-none-eabi/8.3.1/include-fixed" -Wl,--unresolved-symbols=ignore-in-object-files -Wl,--entry=0 -o CMakeFiles/cmTC_6fed0.dir/src.c.obj -c src.c
Source file was:
int main(void) { return 0; }
The target system is: Generic - 2.2.0 - arm The host system is: Darwin - 19.2.0 - x86_64 Checking whether the ASM compiler is GNU using "--version" matched "(GNU assembler)|(GCC)|(Free Software Foundation)": arm-none-eabi-gcc (GNU Tools for Arm Embedded Processors 8-2019-q3-update) 8.3.1 20190703 (release) [gcc-8-branch revision 273027] Copyright (C) 2018 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Using ccs 1.2
using west.0.7.2
Tried deleting ~/Library/Caches/zephyr
This is where the last ticket left off.
