the timer is 6 times faster
I updated a working project based on nRF52832_xxAA 32Mhz crystal, from nRF5 SDK 14.2.0 to nRF5 SDK 16.0.0
now the timer is 6 times faster,
the code hasn't changed
is there any setting i miss?
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
const nrf_drv_timer_t TIMER_SYS = NRF_DRV_TIMER_INSTANCE(1);
#define TIMER_PERIOD 10 /**< Timer period. System timer will expire every 10 ms */
void TIMER_Init(void)
uint32_t time_ticks;
uint32_t err_code = NRF_SUCCESS;
//Configure TIMER for 10ms interval
err_code = nrf_drv_timer_init(&TIMER_SYS, &timer_cfg, timer_sys_event_handler);
time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_SYS, TIMER_PERIOD);
nrf_drv_timer_extended_compare(
&TIMER_SYS, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
nrf_drv_timer_enable(&TIMER_SYS);
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
  • Are you sure you are seeing 6 times the speed, and not 8 or 4? The reason I ask is because it sounds like a prescaler setting. Check out the example in SDK\examples\peripheral\timer.
    My guess is that during your porting, you have missed some sdk_config.h definitions or something.
    Try to debug nrf_drv_timer_init() and see if the number of ticks set is correct, and if it is not, why it is not set correctly.
    BR,
    Edvin
  • I use default (16 MHz)
    the strange thing is that if set TIMER_PERIOD to 1ms OK  2ms OK,  > 2ms the time is wrong
    What could it be?
    I would need it at 10ms but for this problem I set it at 2ms
  • what does nrf_drv_timer_ms_to_ticks() return when you set 1, 2 and >2? E.g. 3 or 10?
