Hi I am using NRF52 board to interface analog sensor and this board further transmit the data ro sink node. I am using saadc example but unable to get callback or my interrupt handler is not working.Kindly suggest
#include "api.h"
#include "node_configuration.h"
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "hardware_config.h"
#include "nrf_delay.h"
#include "power.h"
#include "app_scheduler.h"
#define SAMPLES_IN_BUFFER 5
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t m_ppi_channel;
static uint32_t m_adc_evt_counter;
uint16_t data_adc;
uint8_t count=0;
void timer_handler(nrf_timer_event_t event_type, void * p_context)
count++;
_send_data((uint8_t*)&count, 1, APP_ADDR_ANYSINK, 28, 28);
uint32_t err_code;
nrf_drv_ppi_init();
_send_data((uint8_t*)&err_code, 4, APP_ADDR_ANYSINK, 10, 13);
// setup m_timer for compare event every 400ms
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
_send_data((uint8_t*)&ticks, 4, APP_ADDR_ANYSINK, 10, 14);
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
// setup ppi channel so that timer compare event is triggering sample task in SAADC
_send_data((uint8_t*)&err_code, 4, APP_ADDR_ANYSINK, 10, 15);
timer_compare_event_addr,
saadc_sample_task_addr);
_send_data((uint8_t*)&err_code, 4, APP_ADDR_ANYSINK, 10, 16);
uint32_t err_code;
err_code = nrf_drv_ppi_channel_enable(m_ppi_channel);
_send_data((uint8_t*)&err_code, 4, APP_ADDR_ANYSINK, 11, 11);
uint32_t err_code;
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
_send_data((uint8_t*)&err_code, 4, APP_ADDR_ANYSINK, 13, 11);
int i;
for (i = 0; i < SAMPLES_IN_BUFFER; i++)
// NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
data_adc=p_event->data.done.p_buffer[i];
_send_data((uint8_t*)&data_adc, 2, APP_ADDR_ANYSINK, 13, 10);
m_adc_evt_counter++;
void saadc_init(void)
uint32_t err_code;
nrfx_saadc_uninit();
nrf_saadc_channel_config_t channel_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
_send_data((uint8_t*)&err_code, 4, APP_ADDR_ANYSINK, 14, 13);
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
_send_data((uint8_t*)&err_code, 4, APP_ADDR_ANYSINK, 14, 14);
err_code=nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
_send_data((uint8_t*)&err_code, 4, APP_ADDR_ANYSINK, 14, 15);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
_send_data((uint8_t*)&err_code, 4, APP_ADDR_ANYSINK, 14, 16);
void App_init(const app_global_functions_t * functions)
Power_enableDCDC();
// Open public API
API_Open(functions);
if (configureNode(getUniqueAddress(),
NETWORK_ADDRESS,
NETWORK_CHANNEL) != APP_RES_OK)
return;
saadc_init();
saadc_sampling_event_init();
lib_state->startStack();
