Can't connect central/peripheral relay to peripheral
Hi
So, Im trying to repeat the ble_central_and_peripheral example but with my own services. To be easier let's call the service  "snsr". So, I did the snsr.c and the snsr_c. I didn't get any errors compiling in both cases. I tried to keep as close as possible to the original example too. So I alter the relay example adapted to search to snsr instead of the default services in a nRF52 board (central/peripheral), and I ran the snsr.c in another nRF52 board, to be the peripheral. With my phone I can detect and connect to the relay board but that board can´t connect to snsr board.
Can someone help me what I can be missing?
This is my ble_snsr_init at ble_snsr.c
uint32_t ble_snsr_init(ble_snsr_t * p_snsr, const ble_snsr_init_t * p_snsr_init)
  uint32_t err_code;
  ble_uuid_t ble_uuid;
  // Initialize service structure
  p_snsr->conn_handle = BLE_CONN_HANDLE_INVALID;
  p_snsr->evt_handler = p_snsr_init->evt_handler;
  // Add service
  ble_uuid128_t base_uuid = SENSOR_UUID_BASE;
  err_code = sd_ble_uuid_vs_add(&base_uuid, &(p_snsr->uuid_type));
  if (err_code != NRF_SUCCESS) return err_code;
  // Add service
  ble_uuid.type = p_snsr->uuid_type;
  ble_uuid.uuid = SENSOR_UUID_SERVICE;
  err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_snsr->service_handle);
    err_code = write_char_add(p_snsr);
    err_code = read_char_add (p_snsr);
    return NRF_SUCCESS;
This is the main.c of snsr peripheral.
static ble_uuid_t m_sr_uuids[] =
   {SENSOR_UUID_SERVICE, BLE_UUID_TYPE_VENDOR_BEGIN}
    ret_code_t         err_code;
    ble_snsr_init_t    snsr_init;
    ble_dis_init_t     dis_init;
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    dis_init.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init);
    // Initialize My Sensor Service
    memset(&snsr_init, 0, sizeof(snsr_init));
    snsr_init.evt_handler          = NULL;
    err_code = ble_snsr_init(&m_snsr, &snsr_init);
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.srdata.uuids_complete.uuid_cnt = sizeof(m_sr_uuids) / sizeof(m_sr_uuids[0]);
    init.srdata.uuids_complete.p_uuids = m_sr_uuids;
And here its some parts of main in relay code.
static void scan_init(void)
 err_code = nrf_ble_scan_filter_set(&m_scan,
                                       SCAN_UUID_FILTER,
                                       &m_sr_uuids[SNSR_SERVICE_UUID_IDX]);
static void filter_settings_change(void)
    err_code = nrf_ble_scan_all_filter_remove(&m_scan);
    if (strlen(m_target_periph_name) != 0)
                                           SCAN_NAME_FILTER,
                                           m_target_periph_name);
    if ((m_conn_handle_snsr_c != BLE_CONN_HANDLE_INVALID) &&
        ( m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID))
                                           SCAN_UUID_FILTER,
                                           &m_adv_uuids[HART_RATE_SERVICE_UUID_IDX]);
    if ((m_conn_handle_hrs_c != BLE_CONN_HANDLE_INVALID) &&
        (m_conn_handle_snsr_c == BLE_CONN_HANDLE_INVALID))
                                           SCAN_UUID_FILTER,
static void snsr_c_evt_handler(ble_snsr_c_t * p_snsr_c, ble_snsr_c_evt_t * p_snsr_c_evt)
    switch (p_snsr_c_evt->evt_type)
        case BLE_SNSR_C_EVT_DISCOVERY_COMPLETE:
            if (m_conn_handle_snsr_c == BLE_CONN_HANDLE_INVALID)
                m_conn_handle_snsr_c = p_snsr_c_evt->conn_handle;
                NRF_LOG_INFO("SNSR discovered on conn_handle 0x%x", m_conn_handle_snsr_c);
                filter_settings_change();
                err_code = ble_snsr_c_handles_assign(p_snsr_c,
                                                    m_conn_handle_snsr_c,
                                                    &p_snsr_c_evt->params.snsr_db);
                // Initiate bonding.
                err_code = pm_conn_secure(m_conn_handle_snsr_c, false);
                if (err_code != NRF_ERROR_BUSY)
                err_code = ble_snsr_c_sns_notif_enable(p_snsr_c);
        } break;
        case BLE_SNSR_C_EVT_SNS_NOTIFICATION:
            m_conn_handle_snsr_c = p_snsr_c_evt->params.sns.snsr_value;
            NRF_LOG_INFO("Sensor: = %d", m_conn_handle_snsr_c);
            err_code = ble_snsr_read_update(&m_snsr, p_snsr_c_evt->params.sns.snsr_value);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(err_code);
        } break;
            // No implementation needed.
Thank you in advance
