cli_agent_ep_handler_ping When to free zb_bufid_t
Setup: Segger Embedded Studio v3.52, nRF5_SDK_for_Thread_and_Zigbee_v4, nRF52840 Custom Board
I based my code off of your Zigbee cli_agent_router example. In the routine cli_agent_ep_handler_ping(zb_bufid_t bufid), the buffer "bufid" is released at certain points, but not everywhere I think it should be released. I've attached the routine below.
/**@brief The Handler to 'intercept' every frame coming to the endpoint
 * @param bufid    Reference to a ZBOSS buffer
static zb_uint8_t cli_agent_ep_handler_ping(zb_bufid_t bufid)
    zb_zcl_parsed_hdr_t * p_cmd_info = ZB_BUF_GET_PARAM(bufid, zb_zcl_parsed_hdr_t);
    zb_uint32_t time_diff;
    if (p_cmd_info->cluster_id != PING_CUSTOM_CLUSTER ||
        p_cmd_info->profile_id != ZB_AF_HA_PROFILE_ID)
        return ZB_FALSE;
    NRF_LOG_INST_DEBUG(m_log.p_log, "New ping frame received, bufid: %d", bufid);
    ping_req_indicate(bufid);
    if (p_cmd_info->cmd_id == PING_ECHO_REPLY)
        zb_uint16_t remote_short_addr = 0x0000;
        /* We have our ping reply */
        ping_request_t * p_request = find_request_by_sn(p_cmd_info->seq_number);
        if (p_request == NULL)
            return ZB_FALSE;
        if (p_request->remote_addr_mode == ZB_APS_ADDR_MODE_16_ENDP_PRESENT)
            remote_short_addr = p_request->remote_addr.addr_short;
            remote_short_addr = zb_address_short_by_ieee(p_request->remote_addr.addr_long);
        if (p_cmd_info->addr_data.common_data.source.addr_type == ZB_ZCL_ADDR_TYPE_SHORT)
            if (remote_short_addr != p_cmd_info->addr_data.common_data.source.u.short_addr)
                return ZB_FALSE;
            return ZB_FALSE;
        /* Catch the timers value */
        time_diff = get_request_duration(p_request);
        /* Cancel the ongoing alarm which was to erase the row... */
        zb_ret_t zb_err_code = ZB_SCHEDULE_APP_ALARM_CANCEL(invalidate_row_cb,
                                                            get_request_row(p_request));
        ZB_ERROR_CHECK(zb_err_code);
        /* Call callback function in order to indicate echo response reception. */
        if (p_request->p_cb)
            p_request->p_cb(PING_EVT_ECHO_RECEIVED, time_diff, p_request);
        /* ...and erase it manually */
        if (zb_err_code == RET_OK)
            zb_ping_release_request(p_request);
    else if ((p_cmd_info->cmd_id == PING_ECHO_REQUEST) ||
             (p_cmd_info->cmd_id == PING_ECHO_NO_ACK_REQUEST))
        zb_uint8_t     len = zb_buf_len(bufid);
        ping_reply_t * p_reply = ping_aquire_reply();
        if (p_reply == NULL)
            NRF_LOG_INST_WARNING(m_log.p_log, "Cannot obtain new row for incoming ping request");
            return ZB_FALSE;
        /* Save the Ping Reply information in the table and schedule a sending function */
        p_reply->count = len;
        p_reply->ping_seq = p_cmd_info->seq_number;
        if (p_cmd_info->cmd_id == PING_ECHO_REQUEST)
                               "PING echo request with APS ACK received");
            p_reply->send_ack = 1;
                               "PING echo request without APS ACK received");
            p_reply->send_ack = 0;
            p_reply->remote_short_addr = p_cmd_info->addr_data.common_data.source.u.short_addr;
            NRF_LOG_INST_WARNING(m_log.p_log, "Drop ping request due to incorrect address type");
            ping_release_reply(p_reply);
            zb_buf_free(bufid);
            return ZB_TRUE;
        /* Send the Ping Reply, if not possible then invalidate the row */
        ping_reply_send(p_reply);
    else if (p_cmd_info->cmd_id == PING_NO_ECHO_REQUEST)
                          "PING request without ECHO received");
                             "Unsupported Ping message received, cmd_id %d\r\n",
                             p_cmd_info->cmd_id);
    zb_buf_free(bufid);
    return ZB_TRUE;
Can you explain why zb_buf_free(bufid) is not called after:
    // I think zb_buf_free(bufid) should be called here
    return ZB_FALSE;
        return ZB_FALSE;
    return ZB_FALSE;
Thanks!
John
