ODIS fields
I need to add custom information into modem and have found that in v1.2 new ODIS fields were introduced.
As I see I can provide any text for device ID, manufacturer, model and version using AT+ODIS command.
1. As per manual they should be written into flash but that is not happening as data gets reset after power cycle. Is that intentional?
2. Also I see no way to retrieve device id, is that intentional as well?
How these fields are supposed to be used?
All I need is to save some text (5 bytes length) into permanent memory using AT command when modem is off and retrieve it later using UART when it's on.
Thanks
