Custom NRF52840 Board Softdevice Clock Configuration
I am having problems with a custom NRF52840 Board. My program hands at the ble_stack_init function.
I have encoutered this problem in the past so I have tried the different solutions that worked previously. My board uses both a HF and LF.
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
    NRF_CLOCK->TASKS_LFCLKSTART = 1;
I have inserted this functions at the beginning of my main function, and I am able to pass these 2 tests. This should mean that both the HF and LF were successfully initialized.
But my program hangs at ble_stack_init when I set NRF_SDH_CLOCK_LF_SRC to NRF_CLOCK_LF_SRC_XTAL. I have also set the correct accuracy (20 ppm)
It works when I set it to NRF_CLOCK_LF_SRC_SYNTH, But I know this is inefficient.
What could be the problem with the clock setup?
  • C12 and C15 should be closer to 8pF (see 32.768 kHz crystal oscillator (LFXO) chapter for calculation) if the load capacitance of your crystal is CL=6pF.  Wrong loading of the crystal will offset the frequency, but I would still have expected the crystal to ramp up. Have you seen this on more than one board?
  • I have been using this as my reference design and it has been working. The other little thing to note is the LFCLK is physically close to the HFCLK because this is a very small form factor board. Could this be an issue?
  • Could it be a problem with soldering or mounting of the crystal then? Also, did you have multiple boards to test this on, or have you only tested this on one board? I think you should be able to start the crystal even if the layout is not optimal.
  • I agree. I have tested on multiple boards and they call give the same results.
    I am also not able to use the internal RC as the softdevice clock source. I try to select NRF_SDH_CLOCK_LF_SRC as 0, but My program also hangs.
    Is there any other clock setting I am missing in order to use this?
  • You need to specify a calibration interval and also adjust the accuracy when selecting the internal RC oscillator.
    Configuration settings for RC source:
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
