To the kind attention of Nordic support team,
I didn't find in SDK16 any SES version of secured usb bootloader for PCA10100 (tell me if I'm wrong). I mainly modified PCA10056's sdk_config.h (secured usb) project file in order to disable hardware CC310, watching at how flags are set in PCA10040's sdk_config.h (ble secued) project file. I also modified flash_placement.xml, considering nRF52833 flash memory, disabled dual banking behaviour and used nRF52833 start up files. I uploaded the result project, for you to give a look at your convenience if not so much trouble (at least sdk_config.h and flash_placement.xml files), it is a very clean self contained folder containing standard usb secured bootloader compiled to run in PCA10100 DK.
As you can see after building and run, I see using device manager that the SDFU USB peripheral is available for usb updating:
The problem is that when I try to do firmware update I got error messages, so that I cannot really understand if I got the USB bootloader compiled with the very right parameters,
or my problem is coming from a bad usage of nrfutil/ nrfutil version
These are commands I use (please don't pay too attention to names, I quickly copied and pasted changing some name by purpose). I have to say that this procedure worked as a charmed when I was working using nRF52840.
emBuild -config "NRF52833_XXAA" ./xxx.emProject -clean
emBuild -config "Release" ../bootloader/bootloader_usb/build/secure_bootloader_usb_mbr_pca10100.emProject -clean
rem build exe files (main xxx project, usb bootloader)
emBuild -config "NRF52833_XXAA" ./xxx.emProject 2>nul
// merge mbr and main project file
mergehex --merge %NRF_SDK%/components/softdevice/mbr/hex/mbr_nrf52_2.4.1_mbr.hex %XXX%/nRF52833_xxx.hex --output %XXX%/nRF52833_xxx_mbr.hex
// generate settings
nrfutil.exe settings generate --family NRF52 --application %XXX%/nRF52833_xxx.hex --application-version 3 --bootloader-version 2 --bl-settings-version 1 %BOOTLOADER_SETTINGS%/settings_nrf52833_xxaa_app.hex
// merge bootloader and settings
mergehex -m %USB_BOOTLOADER_NAME%/secure_bootloader_usb_mbr_pca10100.hex %BOOTLOADER_SETTINGS%/settings_nrf52833_xxaa_app.hex -o %BOOTLOADER_SETTINGS%/nrf52833_xxaa_bl_w_settings.hex
nrfjprog -f nrf52 --eraseall --snr %SWD_SNR_833%
nrfjprog -f nrf52 --reset --snr %SWD_SNR_833%
nrfjprog -f nrf52 --program %BOOTLOADER_SETTINGS%/nrf52833_xxaa_bl_w_settings.hex -r --snr %SWD_SNR_833%
//rem nrfjprog -f nrf52 --program %NRF_SDK%/components/softdevice/mbr/hex/mbr_nrf52_2.4.1_mbr.hex -r --snr %SWD_SNR_833%
nrfjprog -f nrf52 --program %XXX%/nRF52833_xxx_mbr.hex -r --snr %SWD_SNR_833%
After that I can see that bootloader is apparently getting started correctly when pressing Button 4 after a reset (as you can see in the attached image). And main program is also correctly working. I also checked flash memory layout using nRFConnect and it seems to be quite ok. Of course, I leave to you last word, otherwise there would be no point in asking your kind opinion about this thing:
But then, something like that is failing (I'm pretty sure to use private key that is corresponding to the public one I use to compile the bootloader project):
nrfutil.exe pkg generate --hw-version 52 --sd-req 0 --application-version 4 --application %XXX%/nRF52833_xxx_mbr.hex --key-file %USB_BOOT_PRIVATE_KEY_PATH%/private.key %DFU_PKG_PATH%/keyboard_dfu_pkg.zip
nrfutil.exe dfu usb-serial -pkg %DFU_PKG_PATH%/keyboard_dfu_pkg.zip -p %USB_COM_SECURED_BOOTLOADER_RUNNING%
This is what I get when using nrfutil version 6.1.0:
File "c:\users\astella\appdata\local\programs\python\python38\lib\runpy.py", line 193, in _run_module_as_main
return _run_code(code, main_globals, None,
File "c:\users\astella\appdata\local\programs\python\python38\lib\runpy.py", line 86, in _run_code
exec(code, run_globals)
File "C:\Users\astella\AppData\Local\Programs\Python\Python38\Scripts\nrfutil.exe\__main__.py", line 7, in <module>
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 764, in __call__
return self.main(*args, **kwargs)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 717, in main
rv = self.invoke(ctx)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 1137, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 956, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\click\core.py", line 555, in invoke
return callback(*args, **kwargs)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\__main__.py", line 1014, in usb_serial
do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, serial_number, False,
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\__main__.py", line 970, in do_serial
dfu.dfu_send_images()
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
self._dfu_send_image(self.manifest.application)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\dfu\dfu.py", line 95, in _dfu_send_image
self.dfu_transport.send_init_packet(data)
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 256, in send_init_packet
self.__execute()
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 421, in __execute
self.__get_response(DfuTransportSerial.OP_CODE['Execute'])
File "c:\users\astella\appdata\local\programs\python\python38\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 504, in __get_response
raise NordicSemiException('Response Code {}'.format(
pc_ble_driver_py.exceptions.NordicSemiException: Response Code InvalidObject
This is what I get when using nrfutil version 5.2.0:
File "nordicsemi\__main__.py", line 1464, in <module>
File "click\core.py", line 764, in __call__
File "click\core.py", line 717, in main
File "click\core.py", line 1137, in invoke
File "click\core.py", line 956, in invoke
File "click\core.py", line 555, in invoke
File "nordicsemi\__main__.py", line 1001, in usb_serial
File "nordicsemi\__main__.py", line 956, in do_serial
File "nordicsemi\dfu\dfu.py", line 129, in dfu_send_images
File "nordicsemi\dfu\dfu.py", line 97, in _dfu_send_image
File "nordicsemi\dfu\dfu_transport_serial.py", line 256, in send_init_packet
File "nordicsemi\dfu\dfu_transport_serial.py", line 421, in __execute
File "nordicsemi\dfu\dfu_transport_serial.py", line 505, in __get_response
[27580] Failed to execute script __main__
