Hi, I am using the nRF52840 DevBoard with SDK 16.0 and Mesh SDK 4.1 and am building on the light_switch_client example.
I am trying to change the publication address by PC using UART. I added all the UART dependencies to my project.
So far, UART is working and i can compile my project. However changing the publication address when using UART does not work. When I call my function change_publication_address() through a button press, it changes the address and i can send to a different server node, but if I call change_publication_address() inside my uart_event_handle() function, I get the error app_error_weak.c, 105, Mesh assert at 0x00027B36 (:0) in the RTT_Viewer. I've been on this problem for quite some time now and can't figure it out. I really dont want to make 100 models and change the publication address of each one.
I also found out that when i have my client reset, meaning not provisioned and no publication addresses set, i get no error when entering the uart_event_handle() function.
Can someone please have a look at it? I upload the whole main file since the problem might be somewhere else aswell.
/* Copyright (c) 2010 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Models */
#include "generic_onoff_client.h"
#include "generic_onoff_server.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "example_common.h"
#include "app_onoff.h"
#include "ble_softdevice_support.h"
/* UART stuff */
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
static dsm_handle_t publish_address_handle = DSM_HANDLE_INVALID;
static uint16_t destination_address; // global destination address variable
* SERVER config
* Definitions
#define ONOFF_SERVER_0_LED (BSP_LED_0)
#define APP_ONOFF_ELEMENT_INDEX (0)
/* Controls if the model instance should force all mesh messages to be segmented messages. */
#define APP_FORCE_SEGMENTATION (false)
/* Controls the MIC size used by the model instance for sending the mesh messages. */
#define APP_MIC_SIZE (NRF_MESH_TRANSMIC_SIZE_SMALL)
* Forward declaration of static functions
static void change_publication_address(access_model_handle_t handle, uint16_t address);
static uint32_t set_model_publish_address(uint16_t publish_address, access_model_handle_t model_handle);
static void app_onoff_server_set_cb(const app_onoff_server_t * p_server, bool onoff);
static void app_onoff_server_get_cb(const app_onoff_server_t * p_server, bool * p_present_onoff);
static void app_onoff_server_transition_cb(const app_onoff_server_t * p_server,
uint32_t transition_time_ms, bool target_onoff);
* Static variables
static bool m_device_provisioned;
/* Generic OnOff server structure definition and initialization */
APP_ONOFF_SERVER_DEF(m_onoff_server_0,
APP_FORCE_SEGMENTATION,
APP_MIC_SIZE,
app_onoff_server_set_cb,
app_onoff_server_get_cb,
app_onoff_server_transition_cb)
/* Callback for updating the hardware state */
/* Resolve the server instance here if required, this example uses only 1 instance. */
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting GPIO value: %d\n", onoff)
hal_led_pin_set(ONOFF_SERVER_0_LED, onoff);
/* Callback for reading the hardware state */
*p_present_onoff = hal_led_pin_get(ONOFF_SERVER_0_LED);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Transition time: %d, Target OnOff: %d\n",
transition_time_ms, target_onoff);
static void app_model_init(void)
/* Instantiate onoff server on element index APP_ONOFF_ELEMENT_INDEX */
ERROR_CHECK(app_onoff_init(&m_onoff_server_0, APP_ONOFF_ELEMENT_INDEX));
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App OnOff Model Handle: %d\n", m_onoff_server_0.server.model_handle);
* Definitions
#define APP_STATE_OFF (0)
#define APP_STATE_ON (1)
#define APP_UNACK_MSG_REPEAT_COUNT (2)
/* Delay value used by the OnOff client for sending OnOff Set messages. */
#define APP_ONOFF_DELAY_MS (50)
/* Transition time value used by the OnOff client for sending OnOff Set messages. */
#define APP_ONOFF_TRANSITION_TIME_MS (100)
static void app_gen_onoff_client_publish_interval_cb(access_model_handle_t handle, void * p_self);
static void app_generic_onoff_client_status_cb(const generic_onoff_client_t * p_self,
const access_message_rx_meta_t * p_meta,
const generic_onoff_status_params_t * p_in);
static void app_gen_onoff_client_transaction_status_cb(access_model_handle_t model_handle,
void * p_args,
access_reliable_status_t status);
* Static variables
static generic_onoff_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
const generic_onoff_client_callbacks_t client_cbs =
.onoff_status_cb = app_generic_onoff_client_status_cb,
.ack_transaction_status_cb = app_gen_onoff_client_transaction_status_cb,
.periodic_publish_cb = app_gen_onoff_client_publish_interval_cb
static void device_identification_start_cb(uint8_t attention_duration_s)
hal_led_mask_set(LEDS_MASK, false);
hal_led_blink_ms(BSP_LED_2_MASK | BSP_LED_3_MASK,
LED_BLINK_ATTENTION_INTERVAL_MS,
LED_BLINK_ATTENTION_COUNT(attention_duration_s));
static void provisioning_aborted_cb(void)
hal_led_blink_stop();
static void unicast_address_print(void)
dsm_local_unicast_address_t node_address;
dsm_local_unicast_addresses_get(&node_address);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
static void provisioning_complete_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
#if MESH_FEATURE_GATT_ENABLED
/* Restores the application parameters after switching from the Provisioning
* service to the Proxy */
gap_params_init();
conn_params_init();
unicast_address_print();
hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
/* This callback is called periodically if model is configured for periodic publishing */
__LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Publish desired message here.\n");
/* Acknowledged transaction status callback, if acknowledged transfer fails, application can
* determine suitable course of action (e.g. re-initiate previous transaction) by using this
* callback.
void * p_args,
switch(status)
case ACCESS_RELIABLE_TRANSFER_SUCCESS:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer success.\n");
case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer timeout.\n");
case ACCESS_RELIABLE_TRANSFER_CANCELLED:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer cancelled.\n");
ERROR_CHECK(NRF_ERROR_INTERNAL);
/* Generic OnOff client model interface: Process the received status message in this callback */
if (p_in->remaining_time_ms > 0)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d, Target OnOff: %d, Remaining Time: %d ms\n",
p_meta->src.value, p_in->present_on_off, p_in->target_on_off, p_in->remaining_time_ms);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d\n",
p_meta->src.value, p_in->present_on_off);
static void node_reset(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset -----\n");
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
/* This function may return if there are ongoing flash operations. */
mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
node_reset();
#if NRF_MESH_LOG_ENABLE
static const char m_usage_string[] =
"\n"
"\t\t------------------------------------------------------------------------------------\n"
"\t\t Button/RTT 1) Send a message to the odd group (address: 0xC003) to turn on LED 1.\n"
"\t\t Button/RTT 2) Send a message to the odd group (address: 0xC003) to turn off LED 1.\n"
"\t\t Button/RTT 3) Send a message to the even group (address: 0xC002) to turn on LED 1.\n"
"\t\t Button/RTT 4) Send a message to the even group (address: 0xC002) to turn off LED 1.\n"
"\t\t------------------------------------------------------------------------------------\n";
static void button_event_handler(uint32_t button_number)
/* Increase button number because the buttons on the board is marked with 1 to 4 */
button_number++;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
uint32_t status = NRF_SUCCESS;
generic_onoff_set_params_t set_params;
model_transition_t transition_params;
uint16_t my_address = 0x0003;
static uint8_t tid = 0;
switch(button_number)
case 1:
case 3:
set_params.on_off = APP_STATE_ON;
case 2:
case 4:
set_params.on_off = APP_STATE_OFF;
set_params.tid = tid++;
transition_params.delay_ms = APP_ONOFF_DELAY_MS;
transition_params.transition_time_ms = APP_ONOFF_TRANSITION_TIME_MS;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
switch (button_number)
case 1:
case 2:
/* Demonstrate acknowledged transaction, using 1st client model instance */
/* In this examples, users will not be blocked if the model is busy */
(void)access_model_reliable_cancel(m_clients[0].model_handle);
status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
hal_led_pin_set(BSP_LED_0, set_params.on_off);
//printf("UART test ");
case 3:
my_address = 0x0002;
set_model_publish_address(my_address, m_clients[0].model_handle);
//change_publication_address(m_clients[0].model_handle, my_address);
case 4:
/* Demonstrate un-acknowledged transaction, using 2nd client model instance */
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
switch (status)
case NRF_SUCCESS:
case NRF_ERROR_NO_MEM:
case NRF_ERROR_BUSY:
case NRF_ERROR_INVALID_STATE:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %u cannot send\n", button_number);
case NRF_ERROR_INVALID_PARAM:
/* Publication not enabled for this client. One (or more) of the following is wrong:
* - An application key is missing, or there is no application key bound to the model
* - The client does not have its publication state set
* It is the provisioner that adds an application key, binds it to the model and sets
* the model's publication state.
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %u\n", button_number);
ERROR_CHECK(status);
static void rtt_input_handler(int key)
if (key >= '1' && key <= '4')
uint32_t button_number = key - '1';
button_event_handler(button_number);
static void models_init_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "adding server model\n");
app_model_init();
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i)
m_clients[i].settings.p_callbacks = &client_cbs;
m_clients[i].settings.timeout = 0;
m_clients[i].settings.force_segmented = APP_FORCE_SEGMENTATION;
m_clients[i].settings.transmic_size = APP_MIC_SIZE;
ERROR_CHECK(generic_onoff_client_init(&m_clients[i], i + 1));
static void mesh_init(void)
mesh_stack_init_params_t init_params =
.core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
.core.lfclksrc = DEV_BOARD_LF_CLK_CFG,
.core.p_uuid = NULL,
.models.models_init_cb = models_init_cb,
.models.config_server_cb = config_server_evt_cb
uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
switch (status)
case NRF_ERROR_INVALID_DATA:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reset device before start provisioning.\n");
case NRF_SUCCESS:
* Change publication address
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Change Publication address\n"); // This is still printed out on the RTT viewer
nrf_mesh_address_t publish_address_stored;
destination_address = address;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "entering function\n");
if(publish_address_handle != DSM_HANDLE_INVALID)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Try Removing last publish address\n");
NRF_MESH_ASSERT(dsm_address_publish_remove(publish_address_handle) == NRF_SUCCESS);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Removing last publish address\n");
if(access_model_publish_address_get(handle, &publish_address_handle) == NRF_SUCCESS)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "1\n");
status = dsm_address_publish_add(destination_address, &publish_address_handle);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "adding new publication address1\n");
if(dsm_address_get(publish_address_handle, &publish_address_stored) == NRF_SUCCESS)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "2\n");
if((publish_address_stored.type == NRF_MESH_ADDRESS_TYPE_VIRTUAL)||(publish_address_stored.type != NRF_MESH_ADDRESS_TYPE_VIRTUAL && publish_address_stored.value != destination_address))
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "3\n");
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "adding new publication address2\n");
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "4\n");
// use the retrieved publish_address_handle
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "5\n");
status = dsm_address_publish_remove(publish_address_handle);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "adding new publication address3\n");
switch(status)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NRF_ERROR_NO_MEM\n");
return;
case NRF_SUCCESS:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "NRF_SUCCESS\n");
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Not defined ERROR\n");
return;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "6\n");
NRF_MESH_ASSERT(access_model_publish_address_set(handle, publish_address_handle) == NRF_SUCCESS); // change the address
static uint32_t set_model_publish_address(uint16_t publish_address, access_model_handle_t model_handle) {
NRF_MESH_ASSERT(access_model_publish_address_get(model_handle, &publish_address_handle) == NRF_SUCCESS);
status = dsm_address_publish_add(publish_address, &publish_address_handle);
if (status != NRF_SUCCESS) {
return status;
} else {
return access_model_publish_address_set(model_handle, publish_address_handle);
* UART
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
/* When UART is used for communication with the host do not use flow control.*/
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
static uint8_t data_array[20];
//static uint8_t index = 0;
uint32_t err_code;
uint16_t my_address;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "UART Event\n");
switch(p_event->evt_type)
case APP_UART_DATA_READY:
app_uart_get(&data_array[0]);
//index++;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "UART Data received: -------------%x\n", data_array[0]);
switch(data_array[0])
case 0x61: // When i send an 'a' from my Python terminal. This is working
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "0x61 pressed, blinking LEDs -------------\n");
//set_model_publish_address(my_address, m_clients[0].model_handle);
change_publication_address(m_clients[0].model_handle, my_address); // This is called correctly
//button_event_handler(0);
case 0x62: // When i send a 'b' from my Python terminal. This is working
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "0x62 pressed, blinking LEDs -------------\n");
//set_model_publish_address(0x0002, m_clients[0].model_handle);
//button_event_handler(1);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "something else pressed\n");
case APP_UART_FIFO_ERROR:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Undifinded UART Handle state\n");
void uart_init(void)
uint32_t err_code;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
UART_HWFC,
false,
NRF_UART_BAUDRATE_115200
#else
NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
* LOCAL CONFIGURATION OF MESH FUNCTIONS
static void initialize(void)
__LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
ERROR_CHECK(app_timer_init());
hal_leds_init();
#if BUTTON_BOARD
ERROR_CHECK(hal_buttons_init(button_event_handler));
ble_stack_init();
gap_params_init();
conn_params_init();
mesh_init();
static void start(void)
rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
if (!m_device_provisioned)
static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
mesh_provisionee_start_params_t prov_start_params =
.p_static_data = static_auth_data,
.prov_sd_ble_opt_set_cb = NULL,
.prov_complete_cb = provisioning_complete_cb,
.prov_device_identification_start_cb = device_identification_start_cb,
.prov_device_identification_stop_cb = NULL,
.prov_abort_cb = provisioning_aborted_cb,
.p_device_uri = EX_URI_LS_CLIENT
ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
ERROR_CHECK(mesh_stack_start());
hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
initialize();
start();
uart_init();
for (;;)
(void)sd_app_evt_wait();
This would be the uart_event_handle() function:
uint32_t err_code;
//index++;
where i call the change_publication_address():
switch(status)
return;
case NRF_SUCCESS:
return;
Thanks.
