Setting up an Segger Embedded Studio on VM
Hi
I have developed a code on Windows using the Segger IDE.
I'm looking for a solution to build an the firmware on the Linux VM to automate the build process to generate the .hex files
I have  been trying to install the Segger IDE on VM but every time i try to install  the error popup "Setup: cannot connect to X server"
Since i cannot connect to display on VM , is there a way to install the IDE on VM so that i can build the firmware
if not possible can someone suggest best appropriate tool and procedure to build the firmware
thanks
TJ
