I was exploring TWI master with TWIS Slave example in SDK16.0.0.
It works for sequential reads in loop-back mode.
Now I connected the simulated eeprom slave to another MCU on another devboard. This MCU does sequential reads on 1024 byte boundaries. So I adjusted the example code's config.h to cater for the MCU's requirements. Everything appears to be working (so I thought). But upon closer inspection, I found out that BIT 7 of the first BYTE sent out by the TWIS is always '0'. For example the actual byte was a 0xFF, I could only see 0x7F being sent out in my logic analyzer. The MCU also receives 0x7F instead of 0xFF. This only happens to the first byte of any sequential read transaction. It does not affect the other succeeding bytes.
The MCU (TW master) follows what is described on Figure 185 of nRF52840 PS v1.1 page 488. Except it reads 1024 bytes after and not just 4.
"Figure 185: A repeated start sequence, where the TWI master writes two bytes followed by reading four bytes from the slave"
The MCU reads 1024 bytes @ address 0x0000, then issues the next Sequential Read command to address 0x0400, then to 0x0800 and so on... until 0xFC00.
All the FIRST BYTES of those addresses get's sent out as 0x7F instead of 0xFF. In short, BIT 7 is always set to '0' on all the first BYTES of any Sequential Read Transaction.
The only thing I modified in eeprom_simulator.c is adding the option to take the Read Address in ees_readBegin.
* @brief Start after the READ command.
* Function sets pointers for TWIS to transmit data from the current address to the end of memory.
static void ees_readBegin(void)
uint32_t read_len = EEPROM_SIM_SEQ_READ_MAX_BYTES;
#if (EEPROM_SIM_ADDRESS_LEN_BYTES == 1)
ees_setAddr(m_rxbuff[0]);
#if (EEPROM_SIM_ADDRESS_LEN_BYTES == 2)
uint16_t rxbuff;
if (TWI_ADDRESS_CONFIG == LITTLE_ENDIAN)
rxbuff = ((m_rxbuff[1] << 8 ) | (m_rxbuff[0]));
rxbuff = ((m_rxbuff[0] << 8 ) | (m_rxbuff[1]));
ees_setAddr(rxbuff);
volatile uint16_t temp_addr = m_addr;
if (m_addr + EEPROM_SIM_SEQ_READ_MAX_BYTES > sizeof(m_memory))
read_len = EEPROM_SIM_SIZE - m_addr;
temp_addr = 0;
(void) nrf_drv_twis_tx_prepare(&m_twis, m_memory + m_addr, read_len);
m_addr = temp_addr;
Here is my config.h
* Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
* @ingroup twi_master_with_twis_slave_example
* @defgroup twi_master_with_twis_slave_example_config Example code configuration
* Configuration for the code presenting TWIS and TWI functionality.
#ifndef TWI_MASTER_WITH_TWIS_SLAVE_CONFIG_H__
#define TWI_MASTER_WITH_TWIS_SLAVE_CONFIG_H__
#ifdef __cplusplus
extern "C" {
#define EEPROM_SIM_SIZE (65536u) //!< Simulated EEPROM size.
/* Maximum number of bytes writable to this slave emulator in one sequential access including
* address of the slave memory. Maximum allowed is 255.
* Note that separate RAM is allocated for the data to be written to slave.
#define EEPROM_SIM_SEQ_WRITE_MAX_BYTES 128
/* Maximum number of bytes writable to this slave emulator in one sequential access.
#define EEPROM_SIM_SEQ_READ_MAX_BYTES 1024 //<! Number of data bytes transfer in single request
#define EEPROM_SIM_ADDR 0x50 //!< Simulated EEPROM TWI slave address.
#define EEPROM_SIM_SCL_S 30 //!< Slave SCL pin.
#define EEPROM_SIM_SDA_S 31 //!< Slave SDA pin.
#define EEPROM_SIM_TWIS_INST 1 //!< TWIS interface used by EEPROM simulator.
/* Flash start address to load the RAM with at startup */
#define EEPROM_SIM_FLASH_ADDRESS 0x40000
/* Slave memory addressing byte length */
#define EEPROM_SIM_ADDRESS_LEN_BYTES 2
/* if EEPROM_SIM_ADDRESS_LEN_BYTES == 2, below will configure which byte is sent first by master */
* @enum address_byte_endian
* @brief Endianness of the address byte that is received from master.
typedef enum
/*lint -save -e30*/
BIG_ENDIAN = 0, /**< MSB is sent first by master for address. */
LITTLE_ENDIAN, /**< LSB is sent first by master for address. */
} address_byte_endian;
#define TWI_ADDRESS_CONFIG BIG_ENDIAN
/* Master Configuration */
#define MASTER_TWI_INST 0 //!< TWI interface used as a master accessing EEPROM memory.
#define UART_TX_BUF_SIZE 1024 //!< UART TX buffer size.
#define UART_RX_BUF_SIZE 32 //!< UART RX buffer size.
#define TWI_SCL_M 3 //!< Master SCL pin.
#define TWI_SDA_M 4 //!< Master SDA pin.
#define IN_LINE_PRINT_CNT (16u) //!< Number of data bytes printed in a single line.
#ifdef __cplusplus
#endif // TWI_MASTER_WITH_TWIS_SLAVE_CONFIG_H__
Take note
There is nothing specific @ 0x40000. It is a blank area with just 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF....
What the MCU gets when it tries to read it is 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF..
It does not matter what address the MCU tries to read. The first BYTE of that Read Address will always be affected and will always loose the first bit to '0'.
Is this an issue with the EasyDma ?
Best Regards,
Brad
