I have implemented ias serive with nRF51 and SDK 12.3, but not generating any ble event with IAS service. The code is working fine when compiled in a different machine running with SES 4.30c, but I don't think this will be compiler issue. I used the same files in both machines including startup files. The other machine has SES 4.50.
The device can successfully connect to "nRF Connect" running in a mobile but no event is generated for an alert level write/update. I have found the newer version of IAS (with SDK 16) has a security mode, but not in SDK 12.3. Is this an issue?
Initialization is
/**@brief Function for initializing services that will be used by the application. */ static void services_init(void) { /* Initialize the services used by the application */ uint32_t err_code; ble_ias_init_t ias_init; ble_bas_init_t bas_init; // Initialize IAS Service. memset(&ias_init, 0, sizeof(ias_init)); ias_init.evt_handler = on_ias_evt; err_code = ble_ias_init(&m_ias, &ias_init); APP_ERROR_CHECK(err_code); // Initialize BAS Service. memset(&bas_init, 0, sizeof(bas_init)); bas_init.evt_handler = on_bas_evt; bas_init.support_notification = true; bas_init.p_report_ref = NULL; bas_init.initial_batt_level = 0; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm); BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm); BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm); err_code = ble_bas_init(&m_bas, &bas_init); APP_ERROR_CHECK(err_code); }
s130_nrf51_2.0.1_softdevice.hex is used with the project.
