Can we increase the packet size in Nrf52 Beacon example ? I want to send UUID=16 Bytes + Major=4 Bytes, Minor= 4 Bytes + RSSI= 1 Byte i.e Total =25 Bytes. I am using SDK13.
You may not increase the advertising packet size over its 31 byte limit. You should also keep in mind that there are 2 byte overhead with each bitfield, that you must also send.
Please see this previous ticket on the subject - it is old, but still relevant.
Or, could it be that you are asking about Advertising extension?
Karl
I am not sure I understand what you are asking here.
The contents of the advertising packets must be defined by yourself, and may not exceed 31 bytes - which is my answer to your original question of "can we increase the packet size".
Each bit field must have both a type and length byte, in addition to their contents - this is what makes up their "2 byte overhead".
As an example, a 16-bit UUID will require 4 bytes of advertising packet space, since there is 1 type byte, 1 length byte and 2 UUID content bytes.
You might find the discussion in this ticket useful to have a look at.
Could you share the code snippet where you generate your advertising data, and perhaps also any errors you are encountering?
I highly recommend this tutorial by my colleague, for familiarizing with BLE advertising.
Karl
I know that the packet size should not exceed 31 bytes. But my question is can we remove few fields liked flags and increase the major and minor size ?
